Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Xulfiqar
  • 1 Post By Proverbial_Slang
Thread: Vitz pickup issue after tappets adjust
    hammad_GCu's Avatar
    Mar 2008
    26
    12
    Default Vitz pickup issue after tappets adjust
    I have recently had my head tappets adjustment from Time Engineering Neela Gumbad after hearing from almost 4 to 5 mechanics that its tappets are tight. Head was removed and two out of sixteen valves replaced and others grinded as required. The problm i was facing is now totally removed. ie vibration like missing at cold engine. Engine sound seems also to be good enough.
    BUT PICK SEEMS TO BE LESSER THAN BEFORE.
    Any suggestions please.
    Similar Threads:
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    check the valve clearances properly.
    And good luck with that, because you just ruined your valves by grinding them.
    aamirq's Avatar
    Oct 2006
    31
    1,731
    26 Post(s)
    xulfi bhai i own a 2006 altis auto vvti,the car has done 1 lack 60k km. i wanted to ask does the timing chain need to be replaced ya does it last till the end life of the car?
    "The world ain't all sunshine and rainbows. It's a very ruff, mean place, and no matter how tuff you think you are, it will always bring you to your knees and keep you there permanently if you let it.You or nobody ain't never gonna hit as hard as life, but it ain't about how hard you hit, it's about how hard you can get hit and keep moving forward, how much you can take and keep moving forward. If you know what you're worth, go out and get what you're worth, but you gotta be willing to take the hit."
    - Sylvester Stallone
    Proverbial_Slang's Avatar
    May 2005
    3,906
    29 Post(s)
    I agree with Xulfiqar.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    It can be due to bad timing as most of mechanic in pakistan mess up while placing timing belt or chain
    Sent from my GT-I9105 using PW Forums mobile app
    ahmedk06's Avatar
    Jul 2009
    39
    569
    10 Post(s)
    If your car is smooth then probably bad timings, bad CVT oil.
    Timing Chain should be changed only if it starts to give weird noises, its mostly like a air pressure pipe on loose at high revs. Once a fielder started to give timing chain noise at high revs and we were in naran, came back easily to isb with no performance issues.
    gujar96's Avatar
    Sep 2012
    Rawalpindi
    32
    895
    19 Post(s)
    Why did you grind the valves?
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    Quote Originally Posted by aamirq View Post
    It does need require replacement for life.
    I have recently sold a 2002 Se Saloon Auto with 305,000 km on factory timing chain.
    All life is an experiment. The more experiments you make the better.
    Site Banned Follow
    hqrizwan's Avatar
    Nov 2011
    40
    55
    Hey I have a vitz 2001 the petrol consumption is too much even when its half the tank is it the affect of the tires cause their 185 65 r14
    Regards,
    hqrizwan@gmail.com
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    If you have done proper oil changes, the chain is pretty long life. But do check for slack - align the timing marks and check how much off they are. If they are off by more than 4 degrees then replace the chain.
