Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: My Vitz is vibrating Too much.
    zohaibbadarpura's Avatar
    Feb 2010
    13
    Exclamation My Vitz is vibrating Too much.
    hello
    Expertz
    I have one Question that My Vitz 2001 CNG is vibrating too much in Drive and when i start my Car.I already Changed my Coils and Spark Plugs and Air Filter ..... But still Facing same problem.... Is there anyone how can stop this vibration.
  2. #21
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    A scanner might help diagnose the problem
    haters gonna hate, potatoes gonna potate
  3. #22
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Quote Originally Posted by margallar View Post
    Dost let him discuss its vibration or missing
    93 Accord CB7 (Sold) / 2005 CL7
  4. #23
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Suffocation can make the car vibrate as the exhaust is not getting out freely due to choke cat
    Sent from my GT-I9105 using PW Forums mobile app
  5. #24
    Feb 2010
    13
    asad1 any Shop name or Number of machanic?
  6. #25
    Feb 2010
    13
    Quote Originally Posted by asad1 View Post
    O2 sensor has nothing to do with cng
    it vibrate on petrol too and it vibrate too much on start and Reverse or when i am turning the car at time of Getting out of Parking....sometimes engine stops working suddenly in b/w in Reverse and turning.
  7. #26
    Site Banned Follow
    aussie112's Avatar
    May 2008
    Baku
    33
    20
    Is your engine a 1.0 litre 1KR-FE? This engine is notorious for have the EGR Valve clogged. Since being in Lahore, I have seen countless hundreds of mechanics, both private, and the Toyota dealership, say that "You should remove the Catalytic Converter." This is not solving the problem. In actuality, you are making the Engine WORSE off from removing the Catalytic Converter. This is a very SLIM chance that the Catalytic Converter would be clogged unless it was a very high mileage car and the air/fuel mixture was not problem set (Think MAP Sensor gone bad). The thing is, if it is a bad Catalytic Converter, then it should be replaced with a new one or a good second hand one. Look for the EGR Valve (Located behind the engine, under the intake manifold on the right side) and have it cleaned, along with the EGR passages and see if that sorts it out. You might need a new EGR gasket, and I have a few that I ordered from Japan, so if you need one, private message me.
  8. #27
    Feb 2010
    13
    you all are saying different things..... what should i change or repair ? @aussie112 @Asad1 @afnan.bashir @
    margallar
  9. #28
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,960
    12 Post(s)
    uniinstall cng.
  10. #29
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    You need to get the car checked with a scanner, if the stft (short term fuel trim) is not changing its value continuously, then the oxygen sensor is either dirty or bad.
    @Xulfiqar can tell how to test the egr
    And lastly you should install extra wires for ground, this may solve your problem, even if it doesn't, it is good preventive maintenance.
    I know two cases of vitz showing these symptoms, one time it was a bad oxygen sensor and the other time it was bad ground.
  11. #30
    sajid_lte's Avatar
    Dec 2008
    44
    8
    U clean ur throttle body. After that u can see ur car will OK. I faced this problem and this is its solution.
Tags for this Thread
