Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Like Tree19Likes
Thread: Vitz 2008 Transmission Problem
    ozzeyy's Avatar
    May 2010
    27
    78
    Default Vitz 2008 Transmission Problem
    Hi PWS
    yesterday i went to PirSohawa with friends we were 4 people inside the car. Usually i never get stuck in the heights of pir sohawa but yesterday my car suddenly stopped at last height towards Monal then the car went through at second session.
    while coming back from monal at straight road when i press the accelerator fully, car takes too much time to shift gear and it also gives a high sound but taking much time to increase speed.
    i have made the following maintenance work when i purchased
    at 49000 kms, Transmission oil i.e CVT,engine oil+filter air filters
    *I have changed oil+ filter three times since i bought the car
    currently the car's mileage is 59500
    Kindly help me in this regard . Because every local mechanic gives me different suggestions so i dont know whether to examine the car from Toyota or some other.
    Your response will be appreciated
    Thankyou
    faiz.aslam.121's Avatar
    Jan 2013
    Oslo
    21
    7,464
    5
    148 Post(s)
    4 Thread(s)
    Do get it scanned by Toyota. Some sensor could be malfunctioning and try a general tune up as well
    Turbo lag is like foreplay. You know it's coming. And it's gonna be good.
    CerwinVega's Avatar
    May 2010
    36
    1,574
    22
    213 Post(s)
    2 Thread(s)
    first of all check two basic things
    1. your car is not cng driven ... may be the previous owner removed it after using it
    2. whether you replaced the correct fluid ..... normally mechanics and oil traders dont know the difference between a cvt and automatic gear box .... if they have replaced automatic oil instead of cvt oil then i am afraid your gear will be a guest of few days.
    3. drive the car on normal road and then check the difference in behaviour of car .
    if you still find everything ok then get it checked from any expert
    " Gravity is not responsible for people falling in Love "
    ozzeyy's Avatar
    May 2010
    27
    78
    Thanks brothers
    Its pretty sure the car doesnt have any CNG
    Its totally patrol.
    Sent from my GT-I9001 using PW Forums mobile app
    ozzeyy's Avatar
    May 2010
    27
    78
    My car's gear configuration is P R N D S B and fr this type of gear box the CVT oil is must and i used that one while changing.
    StrikerX's Avatar
    May 2010
    1,240
    61 Post(s)
    2 Thread(s)
    Quote Originally Posted by ozzeyy View Post
    Toyota CVT-TC oil or some other?
    Sent from my Nexus 4 using Tapatalk 2
    ChipLoco.com | Anything and everything from the tech world!
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    change the transmission oil & transmission oil filter, USE Toyota CVT oil only
    Vitz 2008  Transmission Problem -1371069
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    huzaifa.haroon's Avatar
    Aug 2012
    5,003
    10
    225 Post(s)
    7 Thread(s)
    I cant understand the meaning of changing gears in CVT , CVT is continuously variable transmission it changes ratios depending on road and accelerator but it has no gears like auto..
    Sent from my A900 using Tapatalk
    Always respect your parents
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    what would you say changing from P ---> N ---> R --> D --> S --> B , is it not shifting gears
    Aug 2012
    5,003
    10
    225 Post(s)
    7 Thread(s)
    Quote Originally Posted by capsat View Post
    So what does this mean " when I press full accelerator car takes time to shift " ?
    ozzeyy's Avatar
    May 2010
    27
    78
    I mean while driving(on D) it takes a long time to shift, It should change the gear according to the acceleration of the car but only the sound is present without any power
  12. #12
    ozzeyy's Avatar
    May 2010
    27
    78
    Quote Originally Posted by StrikerX View Post
    i have used toyota CVT -Tc which is mentioned above in picture
  13. #13
    StrikerX's Avatar
    May 2010
    1,240
    61 Post(s)
    2 Thread(s)
    Quote Originally Posted by huzaifa.haroon View Post
    Let me rephrase, "when I press full accelerator, car doesn't accelerate (or speed doesn't increase)."
  14. #14
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    ill say , take a drive in another same kinda vitz n thn compare
    its a small engine wid cvt tranny it just doesnt speed up lyk dat , it is kinda lyk dat , gets noisier n gets nowhere !
    drive another vitz on same road n compare both in same situations i think dere would be nuthing wrong wid urz !
    it doesnt downshift lyk an ordinary auto
  15. #15
    arabianmalik's Avatar
    Jul 2011
    Rawalpindi
    29
    76
    Dear, after reading through, it may seem to me that your clutch plate is worn out. Check with toyota,,,....
  16. #16
    Aug 2012
    5,003
    10
    225 Post(s)
    7 Thread(s)
    Let me rephrase, when I press full accelerator, car doesn't accelerate (or speed doesn't increase).
    Ok
  17. #17
    CerwinVega's Avatar
    May 2010
    36
    1,574
    22
    213 Post(s)
    2 Thread(s)
    Dear one thing is for sure .... A vitz 1000cc is under power makes a lot of noise on acceleration and it shift gears with out any jerks so you cant judge it changes the gear or not ..... i think its normal ..... drive another vitz same model same cc and then compare ....
    in case if your car's gear box is weak then notice one things ie till the car is cold it will run smooth but the more you drive and car becomes hot and hot it will keep on loosing initial acceleration makes a lot of noise, specially on hilly areas where cluth plates and pressure plates have to be in a good condition,,,,, one guess in such scenario is that take the automatic gear stick out and smell the oil .... it will smell like something burnt and then you have to change the gear box ultimately
  18. #18
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    When the trans lugs down due to load the variator will move to a lower ratio and keep it there to keep the car moving. This will also overheat the CVTF like overcooked milk. In some cases it will also disengage the start clutch.
    CVT are not meant for towing or high load - for that you need a regular auto or a manual box.
    In Mitsi Lancer and some Nissans there is a CVT overheat lamp that tells you to slow down.
  19. #19
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    Change fluid may HELP!
    There's no car like Mercedes-Benz.
  20. #20
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    Hi PWS
    Thankyou
    pm for details or contact me at cell no
