Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 128
Like Tree65Likes
Thread: Installing Vitz Engine Charade 84
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Cool Installing Vitz Engine Charade 84
    Thanx For all your Suggestions dear PakWheelers especially , Xulfiqar bro Shazo and other i have decided to install Vitz 1 SZ-FE M/T will upload pics of Project Gradually
    CTRL + Q to Enable/Disable GoPhoto.it
    Knowledge is power guard it well !
  2. #21
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    afnan.bashir
    Mujhay bhi bata doun vitz idle situation ma ya load ma vibrate karti ha koi haal ha ?
  3. #22
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    Damnation6
    meray pass 2010 ka model ha but vibration khtm nahi hoti ha
  4. #23
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Quote Originally Posted by Fahad.Ayub View Post
    The first gen vitz was discontinued in 2005 actually
    so is the swap done ?
    i will receive the car this weekend will upload more pics and discuss further issues related
  5. #24
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Quote Originally Posted by Owais_Yunus View Post
    Whoh a lac plus is quite expensive for a 1sz swap. Please do mention the things that were included in this amount.
    And just like afnan bashir mentioned, eventually, you are the one who is going to properly wire the engine for it to run fine as the ustaads would only do enough wiring to make it run. So I would advise you to start reading up on the engine wiring and how to go about doing the wiring and get acquainted with it
    Sent from my HTC One S using PW Forums mobile app
    yeah the ustaad already told me that he will do wiring from outside only. the dashboard wiring must be done by some other guy and that must be me .. lol..and secondly this swap includes Engine plus ..Compressor plus Power steering (Kangi) , Both Axles , Efi fuel pump , Front (Gadri) , the Gadri below the Engine (bottom Gadri) and other stuff . i will tell the whole cost tomorrow with full details. Can you guide me about engine wiring im complete noob in this
  6. #25
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Quote Originally Posted by MADDYBOY View Post
    Damnation6
    Maddy is it Auto or Manual..
  7. #26
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    will upload more pics as soon as i can ..
  8. #27
    Owais_Yunus's Avatar
    Sep 2005
    28
    2,224
    60 Post(s)
    Quote Originally Posted by Damnation6 View Post
    The first step would be to get hold of a wiring diagram or atleast a pinout for the ecu that your engine is running on. You can search for it at Toyota Yaris Forums, Photos, Videos, News, and Discussion - YarisWorld by entering the engine code, 1sz-fe in the search fields. If you cannot find the pin out, you can open up the ecu and the pinout will be printed on the pcb aka the circuit board. You can draw the pin out on a piece of paper. Once you have a hold of the pin out, you need to check the continuity of each wire exiting the ecu to the respective sensor to ensure that the engine side wiring is intact.
    Once the engine side wiring is done, you'll need to focus on the body side wiring because that is where the ustaad would cut corners. Chances are, he'll only connect 2-3 wires i.e. the power and ground and will hand over the car to you. You'll need to rectify the body side wiring for the swap to be a pleasant experience. To do all this, you need to have the pinout handy.
  9. #28
    Sep 2005
    28
    2,224
    60 Post(s)
    And please take lots of pictures of the engine / transmission mounts and the clearances because a friend of mine is interested in swapping a 1sz into his charade and those pics would be helpful in making up his mind about the swap.
  10. #29
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    afnan.bashir
    Most likely it is engine mount.
    93 Accord CB7 (Sold) / 2005 CL7
  11. #30
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    Damnation6
    auto ha
    afnan.bashir
    her bar nahi vibrate karti ha specially brake lagtay waqt ya brake ka bad pick ma
  12. #31
    Sep 2005
    28
    2,224
    60 Post(s)
    Damnation6
    auto ha
    afnan.bashir
    Does your car have cng installed? Or did it have cng installed at some point in time? Did you change the transmission fluid when you got the car?
  13. #32
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    Owais_Yunus
    petrol pa hi chali ha jab se li ha waise abhi tu li ha or cvt oil tu change karwya tha mane khud
  14. #33
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Damnation6
    auto ha
    afnan.bashir
    Do you have original Axles
  15. #34
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    axles mean?
  16. #35
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Question. Does it wobbles or vibrates?
    wobbling under braking shows concern with disks. Under Acceleration it relates to Axles .
    Installing Vitz Engine Charade 84 - Servicecvaxles
  17. #36
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    afnan.bashir
    thank you bhai
  18. #37
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Thanks a lot brother the pathetic ustaad Electrician has just done the wiring of engine bay and said to me that all internal wiring should be done by some other person .and he charged me 4 k for his 2 hour work and he indeed has done some poor work although i have seized some of his money but still i have to do the internal wiring ..i appreciate for your Guidance i will make a diagram of the pinout and search the web ..
  19. #38
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    ok owais im uploading some of the pictures now and will upload more pics of Engine/Transmission mounts and the clearances will upload more pics as soon as possible Insha Allah !Installing Vitz Engine Charade 84 -1382937Installing Vitz Engine Charade 84 -1382938Installing Vitz Engine Charade 84 -1382939Installing Vitz Engine Charade 84 -1382940Installing Vitz Engine Charade 84 -1382941Installing Vitz Engine Charade 84 -1382942Installing Vitz Engine Charade 84 -1382943Installing Vitz Engine Charade 84 -1382944Installing Vitz Engine Charade 84 -1382945
  20. #39
    Sep 2005
    28
    2,224
    60 Post(s)
    Looking forward to the pics. If you dont plan on connecting the ac for now, I'd suggest you to block both the pipes on the compressor so that dirt doesnt find its way into it.
  21. #40
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Money well wasted
    Body kits available for all cars...
    PM for details
