Page 3 of 7 FirstFirst 12345 ... LastLast
Results 41 to 60 of 128
Like Tree65Likes
Thread: Installing Vitz Engine Charade 84
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Cool Installing Vitz Engine Charade 84
    Thanx For all your Suggestions dear PakWheelers especially , Xulfiqar bro Shazo and other i have decided to install Vitz 1 SZ-FE M/T will upload pics of Project Gradually
    CTRL + Q to Enable/Disable GoPhoto.it
    Knowledge is power guard it well !
  2. #41
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Quote Originally Posted by aqibasit View Post
    Money well wasted
    in which aspect share your precious knowledge..
  3. #42
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Quote Originally Posted by Owais_Yunus View Post
    Looking forward to the pics. If you dont plan on connecting the ac for now, I'd suggest you to block both the pipes on the compressor so that dirt doesnt find its way into it.
    yeah brother i will block the pipes of the compressor btw i have the plan to activate the AC in a month or so and secondly the car is Running very well.. but after some time the car Rpm drops with Jerks and i press the padle it goes away and this problem repeats in intervals what probably can be the issue please guide me i will appreciate your help..
  4. #43
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    i need your help afnan my car is now Running very well.. but after some time the car Rpm drops with Jerks and i press the padle it goes away and this problem repeats in intervals what probably can be the issue please guide me i will appreciate your help..
  5. #44
    Owais_Yunus's Avatar
    Sep 2005
    28
    2,224
    60 Post(s)
    Is the check engine light connected? You can draw codes if the check engine light is connected and if the ecu is showing any errors. If its not connected, the first step would be to connect it. You can connect an led to it for the time being. To find the wire for the cel, you'll need to either open the ecu or find a pinout for it. One of the pins would say 'CEL'.
    The issue you're facing seems to point towards the fuel pump or the maf sensor in the aircleaner housing. How much fuel does the tank have? Try putting in more fuel to atleast fill the tank halfway. Its quite possible that the pump is not properly dipped into the fuel due to the position where its installed. The pump itself could be faulty aswell.
    Sent from my HTC One S using PW Forums mobile app
  6. #45
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Quote Originally Posted by Damnation6 View Post
    Congrats. I have seen the bay it looks neat.
    Leave everything behind and focus on getting
    1. Check Engine Light Installed.
    2. Install ODB2 Connector.
    3. Try driving with gas tank open and then see if RPM drop.
    4. Goto Magic Motors get Fuel Pressure tested.
    5. Now what you have to do is. Buy yourself a Digital Volt Meter, Soldering Iron, Shrink Sleeves and spend one or two weeks completing and verifying the wiring and after that you will enjoy every bit of it
    93 Accord CB7 (Sold) / 2005 CL7
  7. #46
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    it seems that it is not the issue of fuel pump as i installed the fuel pump with mechanic myself and it is properly dipped and fitted no issue with fuel pump.. and today i got the Plug cleaned ..and today i noticed that some wires are not connected they are hanging in engine bay ..i will upload pics and show you ..tonight
  8. #47
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Quote Originally Posted by afnan.bashir View Post
    Thanks brother btw where is magic motors ...there is no issue with fuel pump as i have tested that ..brother i am complete noob in this stuff please tell me:
    1: ODB2 connector and how do i install check engine light ..and plzz tell what is Shrink sleeves ..i will buy digital volt meter i have soldering iron ...i really appreciate your help ..
  9. #48
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    This is the time when you have to give your darling some of your own time not money. Shrink sleeves are hollow covers on which you apply on joints rather than neeto tapes. They shrink when heated This makes the joint secure.
    Tell me the ECU Number of your car.
  10. #49
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    brother you are right but ..can you tell me Where the ECU number is written so that i can upload its pic will upload detailed pics Tomorrow Insha Allah waiting for your response .regards
  11. #50
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    ECU is a box of metal which is usually placed behind the stereo by these electricians.
  12. #51
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    i think this is the ECU and the no. Written on it Installing Vitz Engine Charade 84 -1385406Installing Vitz Engine Charade 84 -1385407Installing Vitz Engine Charade 84 -1385408Installing Vitz Engine Charade 84 -1385409Installing Vitz Engine Charade 84 -1385410
  13. #52
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    why is one Slot empty on the ECU can anyone tell ??
  14. #53
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    This is an automatic transmission ECU, your engine is stuck in limp mode as the ECU cannot "see" the transmission solenoid pack and speed sensors.
    Someone was being cheeky and tore the sticker off. The letter A is visible which is half of the word A/T that should be written there.
  15. #54
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Brother Xulfiqar What should i do with ECU , should i change it and get the Manual one or we can work this out need your help in this regard.
  16. #55
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    replace it
    haters gonna hate, potatoes gonna potate
  17. #56
    osakaboy's Avatar
    Apr 2004
    38
    2,278
    31 Post(s)
    And now at this stage let me add AGAIN
    Money well wasted. You put yourself in never ending troubles and your mechanics will be happy and little rich too.
    I hope there comes a day when cancer goes back to just being a zodiac sign
  18. #57
    Sep 2005
    28
    2,224
    60 Post(s)
    If your car is in limp mode, it wouldnt rev past 3000rpm and would be running very rich. If its not running like that, its not in limp mode and you can keep this ecu because it wont be easy to find a manual ecu but if you do find the manual one, it would be best to replace it.
  19. #58
    Sep 2005
    28
    2,224
    60 Post(s)
    Quote Originally Posted by osakaboy View Post
    Thats not the story of every swap. True, he'll go through a lot of frustration at the beginning but once he gets everything done properly, it would be worth the effort and thats how one learns.
  20. #59
    mansoor_qadir's Avatar
    Sep 2012
    Attock
    1,476
    11 Post(s)
    Partially right par shoq ka mol jo koi nai.
    <..If everything seems under control, U r not going fast enough..>
  21. #60
    Damnation6's Avatar
    Feb 2010
    27
    1,111
    9 Post(s)
    Sorry brother ..its not money well wasted there is no issue with the swap. and their are no major troubles that i am facing only minor ones . BTW my brother owns the Shop in Bilal Gunj i have no trouble Replacing any part . A person has to face some Troubles after a swap but its only at the beginning and After that its the real fruit.so thanks for your valuable answer.
