Whoh a lac plus is quite expensive for a 1sz swap. Please do mention the things that were included in this amount.
And just like afnan bashir mentioned, eventually, you are the one who is going to properly wire the engine for it to run fine as the ustaads would only do enough wiring to make it run. So I would advise you to start reading up on the engine wiring and how to go about doing the wiring and get acquainted with it
Sent from my HTC One S using PW Forums mobile app
