Results 1 to 5 of 5
Thread: Toyota Vitz | Using a 15 inch tyre
    abdullahnasim's Avatar
    Dec 2013
    28
    Default Toyota Vitz | Using a 15 inch tyre
    Dear All
    I have a toyota vitz 2010 and it comes with standard 14inch stock tyres. I have a very basic question, is it a good idea to upgrade to 15 inch alloy wheels or should I stick to 14 inches? Please also let me know the reasons behind your verdict
    khm42747's Avatar
    Jan 2013
    1,340
    43 Post(s)
    2 Thread(s)
    Brother the thing is that if u want wider tyres then 15 inch rims will look good and if u are going 15 inch rims and would be using 185 than its no point as 185 65 R14 is the recommended size for vitz.
    So if you're planning to let comfort go and are ready to have looks and grip at high speed than u need to have 15 inch rims otherwise u don't need them.
    Sent from my GT-N7100 using PW Forums mobile app
    Don't Compromise Because So Much Is Riding On Your TYRES.So Be SAFE and Choose Wisely.
    Dec 2013
    28
    Thanks I think I'd rather go with 14 inch rims then because comfort is my first priority and one cant call me a high speed freak either
    ivtec3's Avatar
    Feb 2012
    891
    6 Post(s)
    185/65/R15 shall increase ride height slightly (good for bumps). You have the option of using alloys or jdm stepnies with this size of tires. I would recommend jdm stepnies if you're on a budget and want fuel economy too.
    go for it, cons are very less as compared to pros.
    asim510's Avatar
    Nov 2009
    33
    3,393
    72 Post(s)
    3 Thread(s)
    I have 195/60/15 toyo tires in my ride and suffer from noise issue.
    What's the reason. I crossed all 4 tires and sound is even louder
    Thread is around 80% and manufacture year is 2012 04.
    Sent using portable handheld device.
    Before you criticize someone, Make sure you are better than them.............
  6. 29-03-2014, 08:57 AM
    Newbie
