Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree6Likes
Thread: Vitz 2003 issues
    ibadaslam872's Avatar
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Default Vitz 2003 issues
    Aoa PWer's,
    I bought a Vitz 2003 8 months back. I bought it of PW. First of all, the person I bought it from turned out to be a dealer, which I Uncovered afterwards. The car was sold to me as total original except one fender and bumpers. When I brought the mechanic to show him the car, he told me that the car had touchups all around but was not accidental. He said that the car needed new tires and maintainence. I bought the car and brought it here to Lahore and detailed it with all my love. I spent hours on the car. The next day, I very proudly took out the car and asked my dad to take it out instead of our Liana. We left the house with all my family in the car. The A/C stopped working. The gas leaked. I got all that work done for 6000/-
    Next, the engine oil leaked. The car visited the mechanic 4 times for this. It turned out to be a broken seal. Costed a total of 3500/-. Also had the maintainence done. Costed 6300/-. Next changed the tires. Costed 20000/- Then the suspension came along. Costed me around 14k after some discount. (the bill was 19k but I sold the old parts and all). Now I have some new issues:
    1) The cars front makes a 'tung' noise when braking or crossing speed brakers or turning.
    2) The car's average has dropped from 13-14 to 10.
    3) The floor vibrates when the car is accelerating.
    4) The pick has also reduced.
    I need help with these issues. Your valuable feedback is required. I wanted to remove the CAT filter but I'm not aware of the complications and I have a gut feeling that this isn't the issue. Is it useful removing the CAT?
    ***The car also has a noisy interior. it makes alot of noise when crossing bumps. Anyway to fix this?
    NOTE: This thread is not to accuse Pakwheels or anything. I love Pakwheels. This was entirely a misunderstanding. This is just to let people know that cars online aren't always trouble free. People have developed this concept that Cars on Pakwheels are trouble free and sellers are honest. This is not the case. I also won't mention any details of the seller I got my car from as it would cause issues for him. All I can say is looks are ALWAYS decieving.
    AWAITING YOUR REPLY.
    Under the Coconut tree
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Share tyre size
    Low pick can be due to choked CAT we had same issue and was solved after removing cat although we tried everything like injector fuel pump
    Further more tung sound can be due to movement of coil spring if rubber seal between spring and shocker is removed
    Sent from my GT-I9105 using PW Forums mobile app
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by asad1 View Post
    Share tyre size
    I'm using 175/70/R13
    What model did you have? And did the noise change after removing CAT?
    For the noise, I just got off the phone with the mechanic. He says it's not a big issue. It's the 'Chimtay ke bush'.
    Thank you for your response.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    2002 model no issue with the sound as the CAT is installed in exhaust manifold not in dholki
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Thank you so much for your response. Do you remember the rough cost?
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    500-800 max any mechanic or silencer wala can do this job as no need to cut tge pipe or any just need to unbolt and break CAT but do tell him to remove it completely and start the car before installing pipe as leftover also be removed else they will go in silencer dholki n will make chan chan noise
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    hamaisha gari apni puri tasalee kar kay lo, even if buying from family relative.
    suspension needs to be visually checked.cant say here what might be wrong
    coming back to ur problem it seems like a choked cat converter........get it cleaned with diluted mild acid mixed water
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by hash4u View Post
    Sir we checked the car in every way possible. Gaari ko aisey tyaar kar ke rakha tha ke bas :/
    Khair, Now i'm working on making it ride to be proud of. Or I may just sell it once I'm free from my O Levels exams :p
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,959
    32 Post(s)
    dont get the cat converter removed your car will sound like a riksha get it cleaned
    look it up on the web and watch some videos
    the vibration could be because of bad engine and transmission mounts get them checked
    it would be better to replace the fuel filter and get injectors cleaned ultrasonically
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    I've spent around 40k on this car and it is now trouble free except a few minor issues. Should I keep it now for another year or sell it?
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    [QUOTE=Fahad.Ayub;4301833]dont get the cat converter removed your car will sound like a riksha get it cleaned
    after removal of CAT nothing gonna happen to sound as this model have CAT in manifold not a single sound change
  12. #12
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    @LIANARULES
    Brother first when ever u buy a car do tested rive n check it properly ..... maybe seller has done something maybe he has not no 1 knows ......but making sure everything is perfect before you buy it is way to go
    Khair now you have it
    vibration part can be broken mount as well...just check them ...check wheels if any of them is damaged or not ..some times they do
    cars which are standing for long time have hard tires which also create such problems
    well now you have spent so much why are you thinking of selling it ...keep it drive now you know you have replaced all non working parts so atleast it wont be bothering you in coming days ....
    otherwise buying again another n you may welcome new issues
    Regards
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
  13. #13
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by rozzzzz View Post
    @LIANARULES
    Regards
    Exactly what my father says. 2 people test drove the car and passed it. We checked everything twice. Sadly, when I found out about the touchups, I had paid the token money. I'm not going for a used car after this ever again! I bought a Santro 2007 to find out that it was major accidental from the right side. Sold that at a loss of 170k and told every single thing to the buyer. Now bought this and even this is giving me a loss of over 100k in just 8 months. Everybody lies now. Insha Allah I'll only sell this once we have enough funds for a Brand new car.
    For now,
    I'm working on making it better.
    Insha Allah you'll see a ride in the making during june/july
  14. #14
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Default The car being discussed.
    My Vitz FL 2003
  15. #15
    mansoor_qadir's Avatar
    Sep 2012
    Attock
    1,476
    11 Post(s)
    take good care of it...
    <..If everything seems under control, U r not going fast enough..>
  16. #16
    Muzammil73's Avatar
    Aug 2010
    2,249
    36 Post(s)
    Ive got the same model in FL package. Yours is fl package too i believe. I recommend you to
    i) flush all the lubricants and get new. (If you havent)
    ii) get your cat convertor cleaned. DO NOT get it removed. Its present for a purpose.
    iii) go to some good mechanic and get the boots and bearings of axles checked. Change them if they have finished their life. They are often the culprits for all the unwanted noise.
    iii) check the plugs too. Get iridium plugs if the ones fitted are over.
    iv) get some good feul treatment.
    Youll definetly feel change.
    Honda Civic Fb
    Honda city 1.3 PT (5th Gen)
  17. #17
    Muzammil73's Avatar
    Aug 2010
    2,249
    36 Post(s)
    Thats mine.
    Tbh, im more than satisfied with my car.
    Honda Civic Fb
  18. #18
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by Muzammil73 View Post
    Thats mine.
    Thankyou.
    I had all the necessary lubricants changed. Just have to get the gear oil changed now.
    Would a normal silencer wala know how to clean a cat filter?
    Plugs have been changed.
    Fuel treatment would be?
    I swear my car looked exactly like yours when I went to see it :p
    And I'm also very satisfied with this car (Other then these minor issues). I prefer driving this to my Liana. I feel this is faster and much more comfortable :p
  19. #19
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Upgrades planned for during the summer vacations (if the car remains with me)
    1) Body kit- Rs. 8000 with paint
    2) Foglights - No idea
    3) 1" drop. - No idea
    4) Retrofit projectors (If budget allows)- 5-6k
  20. #20
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    @Muzammil73
    How much did you buy your car for? And toouchups?
