Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Muzammil73
  • 1 Post By Xulfiqar
Thread: O/D Lights Keeps Blinking - Vitz 99
    mkamranasif's Avatar
    May 2014
    100
    5 Post(s)
    Default O/D Lights Keeps Blinking - Vitz 99
    I have a VITZ 1999 model and been using it for quite a long time both on Petrol & CNG.
    I have been facing this issue for like last 2,3 years now due to which i cant take my car on motorway. The issue is that suddenly O/D light starts blinking and when its blinking, car doesn't change the gear up to 5th, it keeps stuck in 4th and behaves like if O/D mode is working.
    I have got it checked on a couple of computers but no error code was appeared and i am literally fed-up of the issue. Any help ?
    May 2014
    100
    5 Post(s)
    anyone please ?
    Muzammil73's Avatar
    Aug 2010
    2,249
    36 Post(s)
    There is no fifth gear.
    Honda Civic Fb
    Honda city 1.3 PT (5th Gen)
    May 2014
    100
    5 Post(s)
    Quote Originally Posted by Muzammil73 View Post
    thanks genius !!
    It goes up to fifth without any problem until the damned light starts blinking !!
    Muzammil73's Avatar
    Aug 2010
    2,249
    36 Post(s)
    1) the car you have never came in 5-speed automatic tranny. Now please dont tell me your car is equipped with a transmission of other car ot that your car is special. Kindly take sometime out and collect some knowledge about the car you drive.
    2) you really need to learn how to talk to somebody on a public forum.
    Cheers.
    Honda Civic Fb
    May 2014
    100
    5 Post(s)
    Cheers.
    my apologies if my comment made you feel bad..
    that's really strange and honestly i didn't know it before.. thanks for the info ... having said that if think yellow o/d light starts blinking, my car doesn't go up-to the final gear and i have to wait until the blinking light is turned off by itself .. once it does it goes up to the final gear and then car runs smoothly
    saadkhangul's Avatar
    Apr 2011
    Sahiwal
    23
    751
    18 Post(s)
    Quote Originally Posted by mkamranasif View Post
    thanks genius !!
    Yeah, and you also might believe in Narnia. good going Sherlock..!!! Your car has no 5th gear. were you high on rooh afza or something when the car shifted to 5th ?
    None of the brave deserve fair....
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    you'll have to get it scanned from a toyota dealership
    https://www.facebook.com/OsamaAbbasPhotography
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    o/d blinking is usually a sign of a shift solenoid failure or transmission range switch - its the unit that is sanwiched between the transmission and the shifter arm where the shift cable attaches.
    Run a scan and you will find the problem.
    When you have this problem the transmission will only work in 2-3 and have 1 shift only, in normal working its three shifts - 1 to 2, 2 to 3 and 3 to 4 - thats final gear. TCC lockup also occurs after its in final gear.
    May 2014
    100
    5 Post(s)
    Thanks alot, will get it checked !!!
