Results 1 to 5 of 5
Thread: Help: Mechanic for Vitz
    cruizer2000's Avatar
    Sep 2009
    33
    56
    Default Help: Mechanic for Vitz
    Hey All,
    Can anybody recommend a good mechanic for Toyota Vitz, 1 NZ FE, 1500 CC engine. I recently went to Toyota Township, but came back dissatisfied.
    I guess the car has electronic settings, for which I need help.
    Help Appreciated.
    Thanks,
    Ali
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    i might be able to help, but what is the issue
    haters gonna hate, potatoes gonna potate
    Sep 2009
    33
    56
    I disconnected the battery and installed a new one. The car started some missing afterwards, but was kind of Okay. now the Rpm hovers between 600 to 800. Also, lately i have started to notice some residue in the exhaust. Before my last oil change, it was not there. (I believe the oil is a little more than the full mark on the dipstick). Also, there is a little strange noise when the fan starts.
    The issue is not huge, but need to get it done with. (For Mental satisfaction also).
    Somehow, I didnt feel that Toyota gave sufficient time or care to the car.
    talhabinomar's Avatar
    May 2011
    26
    2,471
    38 Post(s)
    Go to Suntech Auto Workshop in the line of Toyota Township. It is near the TCS Courier Office on Pecco Road.
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    Quote Originally Posted by cruizer2000 View Post
    on my friend's car we removed a fuse to reset the ecu, that resulted in a check light from the cvt and required a calibration from a scan tool, i suspect something similar for your car.
    the oil might be over filled or if you are having bad luck it can be a dented oil sump (under the engine).
    the fan noise could be something stuck near the fan or maybe a bearing
