Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Like Tree1Likes
Thread: Vitz Transmission Issue (likely)
    s.iqbal's Avatar
    Jun 2014
    9
    Default Vitz Transmission Issue (likely)
    I'm having a weird problem with my Vitz (1000cc) for the past few weeks. Sometimes, when I start the car on A/C after a brief stop (of say 5 minutes) and push the accelerator, there is simply no revving and the car refuses to move at a greater speed than the naturally set speed for 'D'. When I say revv, even the engine sound of high RPM is not there. It's simply like I'm pressing a dummy paddle.
    I got my Transmission fluid changed and the whole gearbox cleaned. I changed the pipes carrying the brake fluid since they seemed pretty clogged but this problem simply refuses to disappear. I don't have much idea about these things work but my hunch is it's most likely some issue with the Gearbox or perhaps the A/C...
    I was about to get my Fuel Injectors cleaned but this type of non-responsiveness can't simply be explained away by clogged injectors. More importantly, once I'm doing 40-50 km/h, the car accelerates to higher speeds quite nicely with or without the A/C on.
    Any ideas, with some logic/evidence are highly appreciated.
    Similar Threads:
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    "place your location ???
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    could be issue with Throttle body or sensor for pedeal
    Hanjiii Kaa Storeey Eehh !
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    if its 05 plus model
    check ur throttle body and drive by wire system !
    s.iqbal's Avatar
    Jun 2014
    9
    I'm in Karachi (Gulshan-e-Iqbal) and my throttle body is good.
    @salmanrasheedpsh what do you mean by drive by wire system? @ekdrifter if it is any issue with the sensor of the pedal, how do I fix it?
    Sincere apologies for the late reply.
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Quote Originally Posted by s.iqbal View Post
    check the connector on the throttle body and make sure it properly fitted with the tab locked..also see if the pins inside the connector are clean or not
    check the connector on your accelerator pedal and ensure the same..
    make sure that the throttle body plate doesn't get stuck because of dirt / sludge
    i'm assuming that you have the vitz 1000cc 3 cylinder 1KR-FE engine with CVT (since you never mentioned what model vitz do you have exactly)
    https://www.facebook.com/OsamaAbbasPhotography
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Drive by wire i mean these vitz dun have a throttle cable
    vvajahat's Avatar
    Aug 2011
    54
    4 Post(s)
    I had this issue and when I went to the toyota dealer they said ur gearbox is damaged and it needs ro be replaced its cvt transmission and its v sensitive so 50k it took to solve the issue they changed the gear
    vitz 2010
    s.iqbal's Avatar
    Jun 2014
    9
    @vvajahat I can understand it's the gearbox if there wasn't any speeding up at all or at least if I could hear the engine hum loudly when I press the gas pedal. Engine not humming can't be associated with gearbox... 50k is quite steep.
    @syncview Yes your assumption is correct.
    So can it be ascertained if there are problems with the gearbox?
    Einstein's Avatar
    Feb 2008
    Rawalpindi
    31
    972
    6 Post(s)
    How many days have passed by since u changed the cvt oil? I have noticed that when u get the cvt oil changed; the car behaves weirdly for a few days. My car used to not move for a couple of seconds when put in D and then it used to kind of move forward in a jump start kind of way. It all settled down after a few days. Maybe the ecu learns the new settings etc. Did u remove the battery terminals when u got some work done? It might have reset the ECU as well
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    u change it simple
  12. #12
    s.iqbal's Avatar
    Jun 2014
    9
    @Einstein Well I changed it very recently but the problem was the reason I decided to change the Oil so that can't be it.
    @ekdrifter From where do I find accelerator sensor?
  13. #13
    Einstein's Avatar
    Feb 2008
    Rawalpindi
    31
    972
    6 Post(s)
    Have u gotten ur car scanned? The fault codes really help a lot in finding the specific issue.
  14. #14
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    get it scaneed first
    its my guess this went wrong and i seen some ppl by passed sensor on a vitx 06 here car was running but behaving ab normal
    u will get new sensor it should be available at parts shop but first conform is it throttle body Gas pedal or CVT
  15. #15
    s.iqbal's Avatar
    Jun 2014
    9
    @ekdrifter and @Einstein Scanning for codes works only when the car has a one of the lights on right? Mine are all clear. If not however, then who could possibly do this? Toyota Motors?
  16. #16
    Einstein's Avatar
    Feb 2008
    Rawalpindi
    31
    972
    6 Post(s)
    There are many sensors and many fault codes and i might be wrong but i don't think engine check light would come on for each and every fault code. You can go to a reputable mechanic in ur area who has that diagnostic tool for vitz and get your car scanned. It will not cost much (300-1000 rs) and you might just find the root cause of this issue.
    Remember any XYZ mechanic who has the diagnostic tool cannot be assumed as a master mechanic for your car.
    I have heard extremely twisted theories by these ustads so make sure you visit the right guy.
  17. #17
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    yes 3s toyota see what comes up
  18. #18
    Newbie Follow
    wajihakamran2005's Avatar
    May 2014
    Dear S. Iqbal
    Simply Reboot the Car Programmer/ software by just unplugging the Battery terminals like:
    1. Remove -ve Terminal first.
    2. Remove the +ve Terminal.
    after 5 minutes,
    3. Plug in the +ve Terminal first.
    4. Plug in -ve Terminal.
    For any issue u can call me at 03339611802
    Regards,
    Kamran
  19. #19
    waqasjamil's Avatar
    Aug 2006
    189
    4 Post(s)
    Check Fuel pump... It could be due to low fuel pressure when you need it while pressing the pedal.
  20. #20
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    you need to recalibrate the throttle. A toyota tech can do it for you
