Results 1 to 10 of 10
Thread: vitz
    Majidkhan567's Avatar
    Dec 2012
    413
    2 Post(s)
    Default vitz
    asalam walikum
    i have vitz 2003 my car is vibrate after 50 to 60 speed i have changed tire, rim were out also set by expert rim repairer, now rim is 100% ok alignment done (kehnchi) also change bt still problem is remain now some mechanic, saying axle problem now what should i do i already spend much , give me some solution i ll be very thankfull
    Dec 2012
    413
    2 Post(s)
    no response ?
    changwani54's Avatar
    Jun 2005
    34
    370
    5 Post(s)
    Instead of "some mechanic" get it checked by a "good mechanic".
    Sent from my SM-G7102 using Tapatalk
    usmanulamin's Avatar
    Jan 2011
    Sialkot
    21
    7,349
    33 Post(s)
    4 Thread(s)
    There might be a problem in the axle as the mechanics told due to which the car starts to vibrate on or above 60km/h.
    I hope some expert from pakwheels could advise you perfectly about what the issue could be.
    heartstoper's Avatar
    Nov 2012
    Mandi bahauddin
    25
    25
    you should check your vitz fuel pump or change plugs and tune it by a good mechanic...
    Dec 2012
    413
    2 Post(s)
    bro also toyota mechanic said axle problem but axle not producing any sound in turning
    Dec 2012
    413
    2 Post(s)
    any one ?
    danijadoon's Avatar
    Sep 2011
    Abbotabad
    10
    Quote Originally Posted by Majidkhan567 View Post
    asalam walikum
    is the vibration is coming from steering or body.
    if its body can you check engine mounts, suspension bushes, and if it is steering then first thing you will be doing is wheel balancing, and if still there, rotate the wheels, as it is really hard to tell without driving a car, but these couple of things wont cost you much
    silent833's Avatar
    Jan 2011
    151
    only check ur inner excel bro ..same thing happns with my platz ...
    qureshi.usama's Avatar
    Feb 2010
    32
    Dear Users,
    This is my first post on Pakwheels forum but I'm an old user and I keep a lookout over the suggestions.
    Recently I bought a Vitz 2005 (Regd 2008).. It has a 15" tire and the tires installed are quite good. The problem I'm facing is that my rear left tire makes a very annoying sound whenever brakes are pressed. The sound is too much that I'm afraid as to what is wrong with it. Though there is a slight work and tune ups required in terms of shocks as the car is making somewhat tuk sound when there's a bump (Thanks to the roads of Karachi)
    Does anyone have any idea or suggestion where I could take the car to get a sincere advice as I'm really afraid of the mechanics and technicians coz every time I go, they try to fool around in order to earn a few more bucks....
    Awaiting expert suggestions from you guys. Thanks!
    Usama
