Results 1 to 12 of 12
Thread: vitz 100c 1KR-FE engine bad fuel economy
    wheel_man's Avatar
    Jun 2014
    Rawalpindi
    Unhappy vitz 100c 1KR-FE engine bad fuel economy
    hello everyone..
    I've a got a vitz 1000cc 3cylinder 2010 fresh import..
    I am getting an average of 7.3 liters with ac in city and approx. 10kmpl on highway with AC I've changed spark plugs and I m using zic a+ engine oil.. i drive in rawalpindi speed about 40-60 kmph ... I've changed the original rims to alloys and I m using a 195/65/R15 Dunlop tyres. I m using saaada petrol the also has knocking problems in low speed with ac...and has a bad pick(acceleration)..experets plz help..
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    remove cat
    or check its o2 sensor
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    have you done tuning? any smoke?
    aamirq's Avatar
    Oct 2006
    31
    1,727
    26 Post(s)
    get the throttle body serviced and have the air filter changed if u still havent got it changed! and even have the fuel filter checked!
    "The world ain't all sunshine and rainbows. It's a very ruff, mean place, and no matter how tuff you think you are, it will always bring you to your knees and keep you there permanently if you let it.You or nobody ain't never gonna hit as hard as life, but it ain't about how hard you hit, it's about how hard you can get hit and keep moving forward, how much you can take and keep moving forward. If you know what you're worth, go out and get what you're worth, but you gotta be willing to take the hit."
    - Sylvester Stallone
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    Use a Mixture of Petrol and High Octane like for eg If you r filling the tank to full then add 1000rs worth high octane first and then fill the rest. Is the car vibrating on D or N if yes than get the throttle body serviced and only use toyota Genuine Air filter and not the cheap one. Dont remove the Cat Convertor now as it is a new car. And hopefully your average will increase. Our fuel does not suite 1kr-fe engine and it gives knocking and missing problems. Saying from my own experience as i have kept 3 of them
    Laws r Made to be Broken
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Quote Originally Posted by wheel_man View Post
    hello everyone..
    switch back to 185/70/R14 replace O2 sensor, replace filters oil, fuel filter (in fuel tank ), air filter, this car very perform over 10 km/L in city and 12+ over highways.
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    Quote Originally Posted by MADDYBOY View Post
    remove cat
    no never remove the cat unless you are replacing it with a new one.
    haters gonna hate, potatoes gonna potate
    waleed911's Avatar
    Sep 2011
    487
    16 Post(s)
    Scan your car, if you get an error code indicating high temperature at O2 sensor then your Catalytic Converter is clogged...
    If that is the case, nowadays some people clean it with acid and it works (although its reliability and durability is yet to be tested)...
    Otherwise, change air filter and use high octane to reduce knocking, because it may also cause poor acceleration and economy...
    Cheers...
    Driving is not about going from point A to point B, it is the point...
    wajahat.awan2012's Avatar
    Feb 2013
    Rawalpindi
    27
    8
    use 40% super n remaining high octane or both in 50 50 ratio. while talking about average first of all u need to change ur driving style. try to speed up in top gear (higher gear) & try to stable ur rpms at about 3000 to 3500 while driving n speed high. if u have done this the only thing left is to take ur vehicle to any toyota dealership for a tune up. that might help..!!
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    get your vehicle scanned and diagnosed properly it is the symptom of bad Catalytic converter get all 3 of them cleaned through acid clean process and yes it is tested and it work's 100 % if the solution is properly mixed in right proportion with water. and the next thing is seems to be laggy oxygen sensor.
    thbaig's Avatar
    Sep 2005
    38
    97
    3 Post(s)
    never remove catalytic converter .
    Minor knocking is acceptable , as it is designed for high humid.
    you need to clean you cat converter and calibrate throttle.
  12. #12
    tanoli16's Avatar
    Jul 2014
    63
    Re-set the vehicles Plz.... by replacing -ve terminal and reconnect after 5-mint.
    ok??
