Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By NiGhTShAdE
Thread: Toyota vitz reduce engine oil
    khurram42's Avatar
    Mar 2011
    Gujrat
    15
    Default Toyota vitz reduce engine oil
    I have toyota vitz 2005/2008 I bought start of 2014 I use ZIC A. But the engine reduce oil nd he doesn't smoke in silencer nd oil gage nd also filter
    revengez's Avatar
    Jun 2010
    777
    2 Post(s)
    How much oil? Minor oil reduction is normal.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    if & when there is oil reduction, very 1st thing I have learned from few selected tech guys at this forum is GO for Compression Test.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    Quote Originally Posted by khurram42 View Post
    Change engine oil and see. Use a thicker oil. Perhaps viscosity grade 5W40.
    NiGhTShAdE's Avatar
    Nov 2011
    29
    918
    62 Post(s)
    Quote Originally Posted by imrananr View Post
    Zic A is 10W40....thicker than this would be 15W40 Zic M or 20W50 Zic Hiflo...
    NiGhT ShAdE>>~
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    Quote Originally Posted by NiGhTShAdE View Post
    Ohooo, I was not aware of that. So he is using a thicker oil already.
    We'll, if the oil consumption is very minor over a long range of distance covered, thane it's fine. He may only need to top up.
    But, if the oil consumption is high, with blue gray smoke from the exhaust then an engine overhaul may be required. Or at least top overhaul with piston ring replacement and engine head inspection and over haul.
    Leakage of oil should also be checked out first.
    PCV operation should also be checked.
    khurram42's Avatar
    Mar 2011
    Gujrat
    15
    It reduce nearly half litter after 4000 km nd there is no smoke.now I use ZIC 20/50 hiflo
    Malik khurram
    khurram42's Avatar
    Mar 2011
    Gujrat
    15
    What is PCV OPERATION
    Malik khurram
    NiGhTShAdE's Avatar
    Nov 2011
    29
    918
    62 Post(s)
    Malik khurram
    Half lit over 4000km....there is absolutely nothing wrong...your engine is pretty good...you shouldn't have shifted to Zic Hiflo then....stay with Zic A....Hiflo is for old engines reducing considerable amount of oil like half lit in less than 1000km .... Hiflo cant protect your good engine like Zic A.....
    Sent from LG Optimus LTE LU-6200 using PW forums mobile app
    NiGhT ShAdE>>~
    khurram42's Avatar
    Mar 2011
    Gujrat
    15
    Thanks
    Malik khurram
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    Malik khurram
    Positive crankcase ventilation
    Check for PCV valve operation
  12. #12
    godsp3ll's Avatar
    Dec 2013
    28
    126
    So where can I get pcv valve checked in Lahore? Where to find new one?
Tags for this Thread
