Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By muradi
Thread: Vitz 2008 1300cc Vibration after battery
    inara72's Avatar
    Nov 2008
    Peshawar
    44
    199
    6 Post(s)
    Default Vitz 2008 1300cc Vibration after battery
    Asalam , today i took off vitz battery to jumpstart our alto ,after putting back battery in vitz i noticed
    the minor vibration in N and engine stopped few times
    car was 100 percent smooth before battery issue
    my mechanic says its only a race issue and you have to adjust race
    its nothing serious or car may adjust itself in few days
    all the signs indicates low rpm / race issue
    after pressing pedal car has no issue at all .
    any suggestions on this
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    ECU has been reseted, will get normal after some time
    Laws r Made to be Broken
    inara72's Avatar
    Nov 2008
    Peshawar
    44
    199
    6 Post(s)
    thank you Brother
    ecu_designer's Avatar
    Nov 2013
    255
    21 Post(s)
    Nothing to worry about, ECU need some time to learn. Just keep on driving soon every thing will be normal like before.
    same happened with my 1.3L vitz
    rambo_bhae's Avatar
    Nov 2013
    29
    201
    6 Post(s)
    if there is no engine light on i , think you should be fine , my city had the same problem i left it for a month with its terminal detached , it'll be ok in a day or two
    Trust onto God and He shall direct your path......
    inara72's Avatar
    Nov 2008
    Peshawar
    44
    199
    6 Post(s)
    thank you everybody ..
