Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
Like Tree8Likes
Thread: Toyota Vitz 2003 Check light on After Cat. Converter removal
    ibadaslam872's Avatar
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    Default Toyota Vitz 2003 Check light on After Cat. Converter removal
    Hey PW's,
    I had my vitz's Cat converter removed after it had become extremely heavy and the average had gone down to 7-8 per liter. I showed it to the exhaust wala. He said that he would remove the cat. He said that no complications would be involved and all. After he had replaced it, the light came on. I first disconnected the terminals (battery) and it went away. It came back after a while. I showed it to toyota who scanned it and told me I needed to replace my Cat converter and O2 sensor. He estimated nearly 120k for both! I went back to the exhaust wala. He sent me to a mechanic of his. The mechanic said that the catalytic converter was choked. The ECU had set the values accordingly. The heat valve had been opened. Now when it was able to get air, it could not re adjust the values. He said that I need to replace the O2 sensor and it would go away as the new sensor would adopt to the conditions. He quoted a total of 4000/- with labour for a Kabuli sensor. I need to get this light to go away. What should I do? I'm really worried! Please reply urgently! Does anyone know any toyota (japenese) spare ppart dealer in Bilal gunj? I need to get a new Oxygen sensor with a Catalytic converter.
    Under the Coconut tree
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    even a brand new sensor won't fix it, but repositioning the sensor might work
    haters gonna hate, potatoes gonna potate
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    Quote Originally Posted by margallar View Post
    How can we reposition the sensor? Should I just buy a new (kabuli) Catalytic converter?
    Sent from my C2105 using PW Forums mobile app
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    Please help, i need to sort out this issue asap.
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    @capsat @Xulfiqar @faisal.imtiaz.16
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    Should I try a Plug defouler kit?
    ahmedwasiq's Avatar
    Nov 2007
    Rawalpindi
    31
    396
    6 Post(s)
    Open the o2 sensor & clean it with petrol
    Inshallab your issue will be solved.
    Sent from my GT-N7100 using PW Forums mobile app
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    you simply wasted time over this forum since 2009, removal of CAT converter is HAVOC for the JDM vehicles. Though cat converter does have a life span but not so short to be replaced at under 200,000 kms. Fater Cat Con Gone, it is not impossible but also not easy to get your vehicle in optimum operating conditions check with @rustam54 he will be of your help but not for free.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    Quote Originally Posted by capsat View Post
    Thanks
    No one else here has issues with it. Should I get a kabuli catalytic converter and install it? @rustam54 , your help is required.
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    Quote Originally Posted by ahmedwasiq View Post
    Did you face this issue aswell? Thanks for the reply. Will definetly try it!
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    Quote Originally Posted by LIANARULES View Post
    Reviews on this?
  12. #12
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    can you collect back the CAT converter from your mechanic / silencer shop? am sure he must have cleaned and sold that for price of gold. to some other fellow. cleaning is possible as DIY or at the silencer shop it self throwing away is a mistake.
  13. #13
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    It was broken. And sort of melted.
  14. #14
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    I had asked him to get me a new one (kabuli) but he assured me that removing it is a better solution.
  15. #15
    saadkhangul's Avatar
    Apr 2011
    Sahiwal
    23
    751
    18 Post(s)
    Try this. It works most of the times. Its cheap.
    None of the brave deserve fair....
  16. #16
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    you mean to say that he will arrange from scrapyard keep fingers crossed while you locate threads for how to clean CAT converter
  17. #17
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    Well, if I buy one and clean it. And then install it, will it work fine? Thank you so much for your help
  18. #18
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    locate & read in these - am not sure but what i have read over the forum cleaning CAT improves and removes the problems.
  19. #19
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    Quote Originally Posted by saadkhangul View Post
    Have you done this to your civic? Where is this availiable here in Pakistan? Thanks
  20. #20
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    @capsat , I'll try to find one asap. If anyone knows of any Spare parts dealer for toyota vitz 2003 parts (bilal gunj) please let me know.
