Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 63
Like Tree8Likes
Thread: Toyota Vitz 2003 Check light on After Cat. Converter removal
    ibadaslam872's Avatar
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Default Toyota Vitz 2003 Check light on After Cat. Converter removal
    Hey PW's,
    I had my vitz's Cat converter removed after it had become extremely heavy and the average had gone down to 7-8 per liter. I showed it to the exhaust wala. He said that he would remove the cat. He said that no complications would be involved and all. After he had replaced it, the light came on. I first disconnected the terminals (battery) and it went away. It came back after a while. I showed it to toyota who scanned it and told me I needed to replace my Cat converter and O2 sensor. He estimated nearly 120k for both! I went back to the exhaust wala. He sent me to a mechanic of his. The mechanic said that the catalytic converter was choked. The ECU had set the values accordingly. The heat valve had been opened. Now when it was able to get air, it could not re adjust the values. He said that I need to replace the O2 sensor and it would go away as the new sensor would adopt to the conditions. He quoted a total of 4000/- with labour for a Kabuli sensor. I need to get this light to go away. What should I do? I'm really worried! Please reply urgently! Does anyone know any toyota (japenese) spare ppart dealer in Bilal gunj? I need to get a new Oxygen sensor with a Catalytic converter.
    Under the Coconut tree
  2. #21
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    @syncview he may guide you correctly
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  3. #22
    saadkhangul's Avatar
    Apr 2011
    Sahiwal
    23
    751
    18 Post(s)
    Quote Originally Posted by LIANARULES View Post
    Have you done this to your civic? Where is this availiable here in Pakistan? Thanks
    Sent from my C2105 using PW Forums mobile app
    No i havent done this. Didnt need to. Faced no such issue, car was fine. I have read online many times that using a spark plug gapper solves o2 reading issue.
    None of the brave deserve fair....
  4. #23
    rustam54's Avatar
    Aug 2006
    1,004
    113 Post(s)
    Quote Originally Posted by capsat View Post
    you simply wasted time over this forum since 2009, removal of CAT converter is HAVOC for the JDM vehicles. Though cat converter does have a life span but not so short to be replaced at under 200,000 kms. Fater Cat Con Gone, it is not impossible but also not easy to get your vehicle in optimum operating conditions check with @rustam54 he will be of your help but not for free.
    Reporting on Duty....Sir!!!!
    Toyota Vitz 2003 Check light on After Cat Converter removal -1465741
    Thanks
    No one else here has issues with it. Should I get a kabuli catalytic converter and install it? @rustam54 , your help is required.
    Well if you are looking to pull out codes, freeze frame data or O2 plots for the rest of the members to take up from there and help you, you may drop by as per your convenience.
    Lets see what the ECU is seeing as a problem
    The Soul's Journey After Death in Islam (www.bit.ly/SoulsJourney) -- Originally Shared by kse101
  5. #24
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by rustam54 View Post
    Drop by where? The code is P0133.
  6. #25
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by saadkhangul View Post
    Thanks. I'll try looking for thiss.
  7. #26
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    I have replied to your PM
    https://www.facebook.com/OsamaAbbasPhotography
  8. #27
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Bump
  9. #28
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    The error code is PO133
  10. #29
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    Looks like u need to change ur O2 sensor, no need to put back a New Cat conv, seen and drove many cars w/o Cat and they work fine, cleaning the o2 might work but if not, u need to replace it
    Laws r Made to be Broken
  11. #30
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
  12. #31
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by muradi View Post
    Will have it cleaned tmrw. I talked to a mechanic at toyota. He quoted 18k-25k if I get it from toyota and 2500-3000 if I get a Kabuli one. Thankss
  13. #32
    margallar's Avatar
    Oct 2009
    9,958
    6
    283 Post(s)
    4 Thread(s)
    hold your horses until @Xulfiqar replies, don't mess with the sensor just yet
    haters gonna hate, potatoes gonna potate
  14. #33
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by margallar View Post
    I've anxiously been waiting for him (@Xulfiqar) to reply. However, cleaning the sensor won't cause any harm, no?
  15. #34
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Bump
  16. #35
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Does anybody in the DHA/cantt vicinty have a ECN327? I need to plot a graph of my car's O2 sensor.
  17. #36
    margallar's Avatar
    Oct 2009
    9,958
    6
    283 Post(s)
    4 Thread(s)
    cleaning it will do more harm than good imo, i have heard of sensors going bad after being cleaned, these people use carb cleaner on sensors
  18. #37
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Oh. It's good I wasn't able to have it cleaned yesterday :p
  19. #38
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    If you don't want to install cat convertor then put a O2 sensor simulator to avoid cell light.
    Never loose hope in life,every step gives u something.
  20. #39
    abzia's Avatar
    Oct 2006
    32
    337
    10 Post(s)
    In my opinion, there is a chance that cable got broken during cat removal. You can rule this out by measuring voltage on the O2 sensor (it should be between 0.1 ~ 0.9V
    By the way how is the fuel consumption? Worse case scenario is that your O2 sensor might be faulty and put you in limp mode, hence increase fuel consumption.
  21. #40
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by argtr65 View Post
    Explain please. Thanks
