Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By mistr47
Thread: Lost car Key (vitz 08)
    mistr47's Avatar
    May 2006
    Rawalpindi
    34
    57
    Exclamation Lost car Key (vitz 08)
    Hello
    Lost the ONLY key we had for vitz 2008. The car is locked and parked inside.
    What to do? Is is possible to open car without breaking the glass/window.
    Any good locksmith in Rawalpindi?
    How will a locksmith make a duplicate key as there is no other key to copy from (just curious)
    loveburger's Avatar
    Sep 2006
    33
    155
    4 Post(s)
    Bro find a used Mehran Key which almost got flat without any sharp pattern and try to unlock ur car without sliding the full key inside the lock , otherwise try to find a proper Lock Master or Key Maker coz its not a big deal to unlock a Vitz without breaking a glass coz u just need to get your car unlocked Immobilizer is not your issue coz ur original key is inside.Wishing u Luck!!!
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    Is it a simple key or a immobiliser remote key?
    Laws r Made to be Broken
    mistr47's Avatar
    May 2006
    Rawalpindi
    34
    57
    Quote Originally Posted by muradi View Post
    Its a simple Key.
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    Quote Originally Posted by mistr47 View Post
    Its a simple Key.
    Then u r lucky, any lock smith can do the job for u,
    If it was an immobiliser one, u would have been screwed
    Tabish1's Avatar
    Feb 2007
    3,068
    24 Post(s)
    try to pull gate from uper side.. and unlock the car.. key marker pull the iginaation switch through wire and make key through that pattern
    Pakistan <3
    mistr47's Avatar
    May 2006
    Rawalpindi
    34
    57
    Does anyone know a good key maker/lock master that provides home service in rwp.
