Results 1 to 10 of 10
Like Tree5Likes
  • 1 Post By chinyoti
  • 1 Post By surplusstock
  • 1 Post By babarhyd
  • 1 Post By Khurram26
Thread: Vitz 2008: ABS + Parking Light (Hand Brake)
    ozzeyy's Avatar
    May 2010
    27
    78
    Default Vitz 2008: ABS + Parking Light (Hand Brake)
    Hi PWS!!!
    Today i got both lights abs and parking light at the same time while driving.. immediately i stopped the car turnoff the engine and switched it again but lights didnt goes off... I thought it may be the brake problem but certainly i have no issues with brakes they are ok.
    suggestions will be appreciated
    Regards
    Name:  ImageUploadedByPW Forums1409981293.154183.jpg
    chinyoti's Avatar
    Sep 2005
    27
    11,952
    5
    107 Post(s)
    5 Thread(s)
    could be anything from a loose grip to a bad sensor, Its better to take it to a reliable place, Get it scanned and rectified properly rather then let any electrician fiddle with it
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    surplusstock's Avatar
    Jun 2014
    2,301
    39 Post(s)
    3 Thread(s)
    Better check with Toyota 3S.
    SURPLUS STUFF.
    babarhyd's Avatar
    Jul 2005
    Hyderabad
    30
    1,956
    94 Post(s)
    4 Thread(s)
    Brake oil check kiya hai?
    Khurram26's Avatar
    Dec 2006
    38
    273
    13 Post(s)
    Get it scanned from Toyota. Most probably it's either of the ABS sensors... and from experience I can guess that it's one of the rear hubs.
    Sent from my SM-N900 using PW Forums mobile app
    ozzeyy's Avatar
    May 2010
    27
    78
    i have got checkup from my mechanic.
    Firstly he has checked with computer and then he removed the back tire and checked all the wirings connected with the sensors. Secondly he removed battery connection but still indications were present at dashboard. He suggested to change the rear hubs because when i applied full brakes the car slips from back side its feeling like you are driving car that has no abs braking system. I asked him about the price of that rear hubs which cost about 4-5000 rupees.Well i am not sure with the price...
    can anyone tell from where can i buy those hubs and how can we check whether they ar original or desi?
    ozzeyy's Avatar
    May 2010
    27
    78
    Quote Originally Posted by babarhyd View Post
    yes brake oil bilkul maximum par hai
    ozzeyy's Avatar
    May 2010
    27
    78
    Quote Originally Posted by Khurram26 View Post
    yes mr Khurram you were right...
    you must know the price of these hubs as well.
    ozzeyy's Avatar
    May 2010
    27
    78
    Thanks everyone for suggestions.
    Khurram26's Avatar
    Dec 2006
    38
    273
    13 Post(s)
    Quote Originally Posted by ozzeyy View Post
    Some time back it was quite expensive. . I don't know the current price though.
    But I do have a suggestion for you. If you intend to keep the car, do not get used/kabli hubs but buy brand new genuine ones... They will be expensive but you will at least be certain that they will last long.
    If you get used ones, only your luck will determine how long they continue to work.
