Results 1 to 4 of 4
Thread: 5w 50 Mobil1 Syntethic for 2007 Vitz expert opinion required
    inara72's Avatar
    Nov 2008
    Peshawar
    44
    199
    6 Post(s)
    Default 5w 50 Mobil1 Syntethic for 2007 Vitz expert opinion required
    Asalam Pak wheelers
    winter is just around the corner and today without any logic i put
    5w 50 mobil 1 Fully Synthetic in my 2007 vitz ,1300cc 2szfe engine
    the recommendations for vitz is 5w 30 and 5w 40 can be used
    i want to know does it will effect my vitz performance (i am mostly worried about any harm to engine
    or degrading performance ) expert opinion required as it cost me 5800 Rs for oil+filter+Airfilter
    previously i used liqui Molly 5w 30 ,5w 40 in my vitz ,good for 8000/10000 KM
    Thank You
    aamirq's Avatar
    Oct 2006
    31
    1,726
    26 Post(s)
    oil should be changed at recommended intervals by the manufacturer and not how long the oil can last! if u go on how long oil can last mobil1 is known to last for 12,000km!
    how much did the oil cost u? and using 5w50 is thicker compared to the oils that uv been using before so ur fuel mileage should go down a bit and ul feel your engine running a bit heavy!
    "The world ain't all sunshine and rainbows. It's a very ruff, mean place, and no matter how tuff you think you are, it will always bring you to your knees and keep you there permanently if you let it.You or nobody ain't never gonna hit as hard as life, but it ain't about how hard you hit, it's about how hard you can get hit and keep moving forward, how much you can take and keep moving forward. If you know what you're worth, go out and get what you're worth, but you gotta be willing to take the hit."
    - Sylvester Stallone
    inara72's Avatar
    Nov 2008
    Peshawar
    44
    199
    6 Post(s)
    oil cost Rs 4800
    5555's Avatar
    May 2009
    25
    688
    3 Post(s)
    5w30 is a better choice
