Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Like Tree1Likes
Thread: Vitz Brake Guidance
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    Default Vitz Brake Guidance
    is it necessary to get the TOOL while changing the front disc pad of the car
    the car is auto (vitz)
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    but no reply
    hornblower's Avatar
    May 2013
    30
    1,746
    75 Post(s)
    No its not necessary ..... Mechanics do this automatically to earn 500 rupees. Correct way is to measure discs thickness and uniformity against oem defined values. If it is within range then no need of turning discs. Once it is out of the defined range , best practice is to replace discs but since its an expensive item so turning is done for unform thickness and smoothness. Gud mechanics do this with help of a micrometer screw guage. So find a gud mechanic for this job. If u can use a screw guage urself then tell machinist to turn it as per ur own value. Defined values for vitz will be available on internet. Google it. My advice to u , dont let the mechanic to turn ur discs until u measure them coz unnecessary turning damages ur rotors. Hope this answer helps.
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    thanks for your precious advise
    can you advise me some good mechanic in lahore?
    hornblower's Avatar
    May 2013
    30
    1,746
    75 Post(s)
    I m in khi bro ..... Know gud mechanics in islamabad tooo but no idea in lahore
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    yeah, tooling is bad, sometimes new pads will fix the wobbling, just break them in nicely
    haters gonna hate, potatoes gonna potate
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    Exactly if the car wobbles then you need to fixed it with the help of tool
    but my problem is not about the wobbling or anything
    my problem is when in the morning i slowly put the brake pedal it makes noise like something is not grip properly like gram gram but on the other side if car runs for 10 - 15 min then there is no noise coming from any of the wheel
    now the problem is very minor but it irrates me alot just to make thing more clear i had changed the disc pad and put the original toyota disc pad but stil the problem is there
    one more thing the problem came few days back when there was heavy rain and car traveled too much in the rain then this problem arise after been driven on rain
    now anyone help me the matter
    hornblower's Avatar
    May 2013
    30
    1,746
    75 Post(s)
    Wet discs do produce sounds..... Ur problem is of loose pads ..... Any brake shims installed?
    hornblower's Avatar
    May 2013
    30
    1,746
    75 Post(s)
    Get ur calliper pins greased also
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    Quote Originally Posted by hornblower View Post
    may be the disc pad are loose but how come they are loose even i have checked each and every thing even i have greased the pins above the disc pad also service calibers but the problem is still there .. . .the brakes are stock no add on like brake shims
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    yeah exactly disc pad produce sound like they are wet
    in your opinion what may the problem ?
  12. #12
    hornblower's Avatar
    May 2013
    30
    1,746
    75 Post(s)
    Get shims installed ..... Ur pads are slipping when forced against the discs on light foot. This will not be happening if u apply brakes with pressure. Had same problem with my civic, shims solved it. Slipping pads usually occurs on worn out pads or non oem pads coz they dont fit in properly due to difference in size, thickness etc
  13. #13
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    just have installed new toyota disc pad for rs 4800
    do i still need to install shims ?
    may be other mechanics suggested me to get it checked for tool if needed then they will get it fix with the tool
  14. #14
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    Vitz Brake Guidance -1478257
  15. #15
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    are u talking about this ?
    if yes then this is already installed
  16. #16
    hornblower's Avatar
    May 2013
    30
    1,746
    75 Post(s)
    If this is installed then rotors require turning ..... Go for it but take it to some sensible and parha likha type machinist ..... Better get it done from toyota people
  17. #17
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    yeah i m also thinking to go for turning
    anyway thanks for your time and concern
  18. #18
    hornblower's Avatar
    May 2013
    30
    1,746
    75 Post(s)
    Ma pleasure .... Best of luck
  19. #19
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    i have done with the turning but still the problem is same as before
    i m not getting what the hell is there which is not getting clear
    any expert person can put some light on this matter
  20. #20
    hornblower's Avatar
    May 2013
    30
    1,746
    75 Post(s)
    It happens with all cars having disc btakes if brake is pressed very softly in slow speed .... Give pedal a manly push bro .... Tootay gi nhn brake .... Press with confidence .... May be this solve ur problem .... Btw have u measured discs thckness ?
