Results 1 to 8 of 8
Like Tree2Likes
  • 2 Post By capsat
Thread: Urgent help, regarding vitz cvt gear
    ashankhalid's Avatar
    Nov 2011
    Pir mahal
    25
    45
    Default Urgent help, regarding vitz cvt gear
    My vitz axle was giving sound so i decided to change it,
    Now,a new issue arrises, when i change the gear to D, the response is 10 sec delayed & a sound like slipping gear is coming while acceleration.
    Need expert advice.
    Nov 2011
    Pir mahal
    25
    45
    Zulfikhar bhai, need ur advice !!
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    Visit some workshop with Toyota scan tool pull the codes and share here, with any maintenance history available?. CVT filter & CVT Fluid need change at every 65000 km.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    chinyoti's Avatar
    Sep 2005
    27
    11,965
    5
    108 Post(s)
    5 Thread(s)
    ^ Change at every 40,000 kms changing around 35-40 is even better in Pakistani dusty conditions I assume
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    @chinyoti cvt fluid & filter change is recommended AFTER 65000 before 80000 kms. ATF fluid between 40000 ~ 60000 kms. READ THIS
    shaheryar.khokhar's Avatar
    Dec 2013
    1,692
    28 Post(s)
    Did you change the complete axles with new one or kabli ? if you have installed the kabli pair, then its inner teeth is sometimes not in proper shape and thus it causes the slipping of the gear when accelerate it.
    Solution: Check the axles and change them again if they requires.
    On the other hand, it might be your transmission but i just shared what happened to me once. Do let us know when you find the problem
    All the best!
    - Honda Civic ES, Build Thread. Link ---> http://goo.gl/3SocBg
    - Honda Civic EG - SiR-T F20B Build Thread. Link ---> http://goo.gl/5Y4W9m
    Nov 2011
    Pir mahal
    25
    45
    Quote Originally Posted by shaheryar.khokhar View Post
    All the best!
    Bro, i have consulted the problem with Mechanic, he suggested to change the gear oil and clean oil filter.
    ( and said , ka oil filter oil sai tarha utha nai raha )
    Should i must go for axle recheck as well ?
    Dec 2013
    1,692
    28 Post(s)
    Quote Originally Posted by ashankhalid View Post
    yes axles can also cause the same issue, it feels like the gear is slipping but in real the axle teeth is slipping, once happened to me when i changed the axles of my civic and ended up replacing them. anyhow, in your case gearbox/gear oil can also be the reason, diagnose both of them..
