Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By nouman_aziz
Thread: Toyota Vitz grinding noise.
    nouman_aziz's Avatar
    Apr 2014
    28
    Default Toyota Vitz grinding noise.
    Hi guys, I hope someone will be able to help me out actually I'm having bad time with my toyota vitz 2010 model. Its 1.0 vvti automatic.
    I can hear weired noise while driving (can't exactly figure out where its coming from) but it more sounds like grinding noise from engine, it only comes when I accelerate.
    I think it could be bearing but i'm not sure. I'd showed it to mechanic and he said probabily some mount is broken (not had a time yet to get this checked out).
    Car's been serviced regularly and looked after very well.
    Looking forward for your suggestions
    Regards
    Nouman
    humayun.chughtai.7's Avatar
    Nov 2013
    Multan
    20
    636
    9 Post(s)
    May be, its a drive belt noise...
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    which city you are in ?
    shahzadmansoor's Avatar
    Feb 2005
    Huddersfield
    36
    272
    I would say adjuster pulley bearing . I had the same problem in my vitz and in my belta a couple of weeks back got the pulley changed from bilal gunj for 1000 rs.
    Sent from my SM-N9005 using Tapatalk 2
    Mubashir4's Avatar
    Oct 2011
    Quetta
    27
    It may be ur engines belt.
    Apr 2014
    28
    Jhelum
    Apr 2014
    28
    Quote Originally Posted by humayun.chughtai.7 View Post
    Thanks brother for your reply, it could be one of pully's bearing as if it was belt then noise should be squeaky.
    Anyway i'll get this checked out as well.
    Apr 2014
    28
    Quote Originally Posted by rajaatta View Post
    Brother Im from jhelum.
    Apr 2014
    28
    Quote Originally Posted by shahzadmansoor View Post
    Thanks brother for sharing your experience. I maybe wrong but grinding noise only comes when I accelerate during driving.
    At idle (when stopped) pully adjuster and belt seems fine, because with/without acceleration (again when car is stopped) it doesn't make any noise.
    If you're still in doubt then I can get it checked out.
    Thanks again
    MONOO's Avatar
    Apr 2009
    29
    1,249
    48 Post(s)
    4 Thread(s)
    i think u should go to toyota dealership, for periodic inspection, i am also using 2008 vitz and is maintained by toyota capital motors, may b they can help u
    Apr 2014
    28
    Quote Originally Posted by Mubashir4 View Post
    Thanks brother for your reply, as I said to brother Humayun and Shahzad. To me it doesn't seems like belt or pully but you may be right.
    I think at this moment I should get belt and pully's checked out as you all brothers are suggesting same thing.
    It may put somesort of load on belt 😕 (confused).
  12. #12
    Apr 2014
    28
    Quote Originally Posted by MONOO View Post
    Thanks for a good suggestion. May I know their contact deails (garage), and any mechanic you suggest who you think is good?
    Thanks again
  13. #13
    MONOO's Avatar
    Apr 2009
    29
    1,249
    48 Post(s)
    4 Thread(s)
    Quote Originally Posted by nouman_aziz View Post
    Thanks again
    toyota capital motors main showroom in islamabad
    TOYOTA CAPITAL MOTORS
    Plot No. 405-406, 9TH Avenue, Sector I-9, Islamabad
    UAN: 111-142-142, Fax No. 051-4444683
  14. #14
    Apr 2014
    28
    Sweet. Appericate it. Thanks
  15. #15
    Mubashir4's Avatar
    Oct 2011
    Quetta
    27
    Some times the belt makes noise due to dryness so make it little bit oily, put some GREECE Oil inside the belt....
  16. #16
    NiGhTShAdE's Avatar
    Nov 2011
    29
    918
    62 Post(s)
    It could be one of the wheel bearing, if you dont hear sound while car is idling. For all other bearings sound should get produced while idling too....
    NiGhT ShAdE>>~
  17. #17
    Apr 2014
    28
    Quote Originally Posted by NiGhTShAdE View Post
    Thanks for your suggestion I'll definatly get them checked out.
    Thanks brother
  18. #18
    MONOO's Avatar
    Apr 2009
    29
    1,249
    48 Post(s)
    4 Thread(s)
    U r welcome
  19. #19
    ahmad155's Avatar
    Nov 2012
    67
    I have somewhat same problem with my Vitz 2005 as it accelerates grinding voice is heard - showed it to a mechanic and he says its compressor problem and AC guys can do it but needs to inspect after opening the thing..
  20. #20
    tsf
    tsf is offline
    tsf's Avatar
    Dec 2008
    46
    Same problem with my 2004 Vitz. I have noticed that the sound comes when accelerating plus at gear shifts. As soon as car is near 40 and then near 60.
    Sent from my GT-I9082 using PW Forums mobile app
