Results 1 to 8 of 8
Thread: Vitz 2008 Electrical Issue
    usmanamjad82's Avatar
    Oct 2006
    34
    679
    6 Post(s)
    Default Vitz 2008 Electrical Issue
    AOA,
    I need Toyota Vitz experts to help me identify and resolve an issue related to my Vitz 2008.
    Issue # 1:
    Car's horn doesn't work properly. During driving, sometimes it works fine, but then suddenly stops working. I have observed that the malfunctioning occurs when ever the car runs through some rough patches on the road.
    Issue # 2:
    Since past one week, the parking lights, and interior panel lights have stopped glowing. Might be some fuse related issue. If yes, please let me know the exact location of fuse box. Thanks!
    Looking forward.
    Thank you.
    ...success takes time, persistence, determination, and most importantly, believing in yourself
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,591
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Vitz 2008 Electrical Issue -1517049
    one fuse box is under the driver side firewall / under the steering & other MAIN one is in the engine bay next to battery. check horn clips for rust or lose connection. for cabin & cluster lights check for fuse under the firewall
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,708
    22 Post(s)
    issue 2 , its parking lyt control lever has points in it which have accumulated carbon deposits, need cleaning
    common issue wid axio vitz switch assemblies
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,591
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    locate non-acidic carbon contact cleaner spray pull & remove knob / lever to spray wait to dry before putting knob / lever back
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    check the fuse box under the dash and the connectors of the headlight switch (they usually plug into the fuse box). they might be burnt
    haters gonna hate, potatoes gonna potate
    Oct 2006
    34
    679
    6 Post(s)
    Still could not locate the fuse box under the steering... Any visual help!!!
    Jan 2011
    Peshawar
    1,708
    22 Post(s)
    Its fuse box is behind glove compartment
    sadatmasood10's Avatar
    Jul 2011
    59
    5
    5
    8 Post(s)
    for horn problem , you need to change your spiral cable
  9. 28-12-2014, 06:44 PM
    PakWheeler
  10. 28-12-2014, 06:45 PM
    PakWheeler
