Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 157
Like Tree28Likes
Thread: Got Vitz Al-Hamd-u-Lillah
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Default Got Vitz Al-Hamd-u-Lillah
    Dear Fellows,
    Recently i had been posting on vitz related forums with my queries, thought it would be better if i share the reason behind it too.
    Got this vitz 109K driven 2SZ FE in very fine condition MASHALLAH.
  2. #61
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    will share pics. do pray it works out.
  3. #62
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    guys since i am experiencing extensive knocking issue on my 2SZ FE vitz. and the issue has been identified by pakwheels experts related with the use of ZIC A+ (5W-20) a less viscous oil. i am going to change the engine oil.
    short listed oils are mentioned below
    Caltex Havoline 5W-40
    Micking Max Super 10W-40
    Shell Helix Ultra 5W-40
    Micking Max premium 5W-50
    all of these will cost between 2500-3500 Rs. I have compared the viscosity of these oils and all of them have considerably higher numbers at 40 and 100 Degrees.
    I have had a personal good experience with Micking so inclined towards using it. probably will go for 10W-40 Max Super Fully synthetic.
    Please give your suggestions for the guidance.
  4. #63
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    i am using shell ultra on my vitz its 2010 model 1000 cc
    it works fine
  5. #64
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Got Vitz ALHAMDULILLAH -1539343Got Vitz ALHAMDULILLAH -1539344got the oil. will get it changed tomorrow IA and will share the findings.
  6. #65
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Guys/experts.
    i am stuck here. i changed the oil after running on Zic A+ for just 1500 KMs.
    Switched to Micking fully synthetic 10/40 however there seems to be no improvement in knocking issue.
    What to do now?
    Should i reset the ECU? Any other thing which i need to check.
  7. #66
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Quote Originally Posted by Thinking View Post
    Guys/experts.
    What to do now?
    10-40 is too viscuous
    Use 5-30 or 5-40
  8. #67
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Quote Originally Posted by salmanrasheedpsh View Post
    Use 5-30 or 5-40
    I doubt that. I believe there is another reason for the knocking.
    need a realistic solution.
    with new 10-40 oil i have seen marked improvement in pickup of the car. earlier it went down with 5-20 oil. now its back where i m starting to get the confidence to beat every city, GLI/XLI out there again .
  9. #68
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Also the knocking is more experienced during day time/hot conditions. early in the morning and at night it becomes negligble automatically.
  10. #69
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    bro use only recommended engine oil grade in ur car which is 5-40
    for knocking use hioctance and regular in 60/40 ratio
    if still knocking issue get ur car ecu scanned and injectors checked
  11. #70
    saadshaukat's Avatar
    Apr 2006
    Taxila
    33
    72
    Default Dirty MAF
    Have you checked your MAF sensor ( Mass air flow)? A dirty MAF significantly hampers performance and mileage of car! You will see improvements in mileage also reset ecu after cleaning MAF
    Where do you get your car fuelled?
    If knocking issue isn't resolved tappet adjustments might be required what is your car's odometer reading
  12. #71
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Quote Originally Posted by saadshaukat View Post
    bro knocking has improved a lot. i have shifted to constitution avenue PSO pump. And with micking oil there is marked improvement in knocking now. Milage is ok around 12 km/l which i think is appropriate.
  13. #72
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    there is another obervation, when i changed the oil the quantity that i put in to meet the mark is around 3.6-3.7 litres. however as per my recent experience with toyota in another car they pul in 4.5 litres.
    toyota mechanic suggested to use around 4.5 litres in 1800 CC corolla. if that is the case should i put in more engine oil (laying with me around quarter of a litre) in the engine - 2SZFE.
    this might also have an impact on knocking. experts please suggest.
  14. #73
    shabbir.53's Avatar
    Jul 2013
    63
    690
    7 Post(s)
    normally fog lights are connected with parking lights but have a separate switch as well.
  15. #74
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Quote Originally Posted by shabbir233 View Post
    thanks.
    noted.
  16. #75
    fouadbakht's Avatar
    May 2006
    3,620
    20
    140 Post(s)
    What you have done till now is okay. Use Hi-Octane fuel in a ratio that is manageable as per your budget. Do use fuel additives (Fuel System Cleaners and Injector Cleaners) once or twice to clean fuel lines. Have you also changed CVT oil. If not, do it.
    https://www.facebook.com/hidefcars
  17. #76
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Quote Originally Posted by fouadbakht View Post
    Thanks for the feed back.
    CVT oil has been changed.
    Can you please confirm the amount of oil that goes in vitz 1.3 any idea? i have put in around 3.5-3.6 litres and it is at the exact level as marked on the dip stick.
  18. #77
    fouadbakht's Avatar
    May 2006
    3,620
    20
    140 Post(s)
    That's correct
  19. #78
    DrUsmanNawaz's Avatar
    Jul 2011
    Wah cantt
    34
    3,939
    19
    166 Post(s)
    2 Thread(s)
    @Thinking
    What is the fuel average u are getting from your car?
  20. #79
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    @DrUsmanNawaz
    Bro Between 12-14. These days I have shifted my driving style to slightly higher revs so mileage has come down to 12.
    But with light foot it was around 14 km/litre.
  21. #80
    huzaifa.haroon's Avatar
    Aug 2012
    5,004
    10
    225 Post(s)
    7 Thread(s)
    Bro not sure about taking any panga with throttle body or cat converter since the car was fine before ECU reset.
    Follow the idle lean procedure!
    Google it!,
    It is necessary after ecu reset
    Always respect your parents
