Results 1 to 4 of 4
Thread: Vitz Engine Swap Advice Needed
    Derby52's Avatar
    Apr 2009
    24
    235
    4 Post(s)
    Default Vitz Engine Swap Advice Needed
    Can someone guide me about how much will it cost to swap my 2003 Vitz Engine from 1SZ-FE to 2SZ-FE or 2NZ-FE or 1NZ-FE. Complete cost including every single work. Will my Chassis support these engines? My Current engine is causing lots of problem and i feel like swap is the only option. And also mention where to get the job done.
    sial_ali's Avatar
    Jul 2007
    25
    2,936
    5 Post(s)
    Sir I think vitz rs same model as yours came with a 1.5ltr engine, dont know if its bolt on fit or not, @Xulfiqar can help
    galant1's Avatar
    Sep 2013
    1,175
    65 Post(s)
    @Derby52
    Tell us model and year? Trans-Automatic or manual? Then tell you about engine options
    Engineer + Car's Passion = Enthusiastic Personality.
    Derby52's Avatar
    Apr 2009
    24
    235
    4 Post(s)
    As i mentioned, model is 2003 and i want to stick with the auto tranny.
