Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Like Tree4Likes
Thread: Vitz Kncok in Noon
    thbaig's Avatar
    Sep 2005
    38
    97
    3 Post(s)
    Default Vitz Kncok in Noon
    Hi,
    Vitz knocking is not a unique topic and every vitz owner have to bear it at some extent.
    I have vitz 2007 , I have observed that it knocks only at noon. Neither in night nor in early morning hours. It is strange but it lead me to think that Vitz knocking may be directly related to operating temperature .
    Is this the case ?
    aamirq's Avatar
    Oct 2006
    31
    1,731
    26 Post(s)
    add hi octane and drive it should solve the problem and secondly change the petrol station from where u fill petrol
    "The world ain't all sunshine and rainbows. It's a very ruff, mean place, and no matter how tuff you think you are, it will always bring you to your knees and keep you there permanently if you let it.You or nobody ain't never gonna hit as hard as life, but it ain't about how hard you hit, it's about how hard you can get hit and keep moving forward, how much you can take and keep moving forward. If you know what you're worth, go out and get what you're worth, but you gotta be willing to take the hit."
    - Sylvester Stallone
    Marschall's Avatar
    Aug 2009
    Chowha saidan shah
    31
    1,145
    24 Post(s)
    Add ceretec to engine oil and use a little mix of hobc u will get knocking once car is under load and climbing at low speed but during straight drive it should be less
    "Stand by your glasses steady and drink to your comrade's eyes.
    Here's a toast to the dead already and hurrah for the next to die."
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    similar experience
    thbaig's Avatar
    Sep 2005
    38
    97
    3 Post(s)
    Quote Originally Posted by Thinking View Post
    similar experience
    I think it is because of engine oil. If we may use thick oil, we might get rid of this knocking.
    As it seems in cold , it is not knocking. Only diff is temperature and it is directly proportional to engine oil
    ustaad_007's Avatar
    Jul 2005
    30
    465
    11 Post(s)
    @thbaig
    Sir use Hi Octane, knocking will be gone IN SHA ALLAH. If you use thick oil, fuel consumption will be ruined, and its not good for the engine in cold weather.
    thbaig's Avatar
    Sep 2005
    38
    97
    3 Post(s)
    Quote Originally Posted by ustaad_007 View Post
    @thbaig
    everyone usually say that. But the point is why regular gasoline not knock in low temperature ?
    If this is the case, car has to knock in either weather.
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    I have experienced more knocking with Zic A+ (5W-20). Earlier was using Toyota oil (10-40) and the knocking was almost not there at all.
    Add octane booster. situation has improved a bit however intend to switch back to 10-40 oil asap. I hope this will surely improve the knocking issue.
    ustaad_007's Avatar
    Jul 2005
    30
    465
    11 Post(s)
    @thbaig
    Sir actually regular fuel is low octane. Low octane means some of the fuel will burn before going to the combustion chamber because of high temperature, thats why it sounds kar kar kar kar. Hi Octane can handle high temperatures.
  10. 30-01-2015, 04:42 PM
    PakWheeler
  11. #10
    ustaad_007's Avatar
    Jul 2005
    30
    465
    11 Post(s)
    @thbaig
    Ok there is one more thing called knock sensor, may be its not working correctly or requires cleaning or replacement.
  12. #11
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    Quote Originally Posted by thbaig View Post
    Hi,
    Is this the case ?
    Avoid driving at noon.....
    Don't leave a highway for a byway....
  13. #12
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    i have same issue... use hioctane ur prblem will be slved.... if it still occurs try getting ur thrtle bdy servced... INSHALLAH after using hioctane ur prblem will be slved.. first empty ur fuel tank by consuming all the petrol. den use almost 2000rs hioctane and den use 60 40 ratio of petrol and hioctane... prblem will be slved... and avoid using TOTAL fuel... i exprencied alot of knocking in my GS150 too after getting fuel from total.. idk what is the reason...
    Why drink and drive when you can smoke and fly?
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
  14. #13
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    i think it has something to do with the ocv which controls the vvti.
    haters gonna hate, potatoes gonna potate
  15. #14
    muhammad.irtiza's Avatar
    May 2014
    26
    117
    5 Post(s)
    The real problem is that when the temperature is high, gas particles inside the shock absorbers gain kinetic energy and expand but when the temperature is lower the molecules lose kinetic energy and come back to their orignal position.
    PROUD OWNERS OF SUZUKI SINCE 1975 (Suzuki Cultus 2005, Suzuki Cultus 2010, Suzuki Liana 2010)
  16. #15
    ustaad_007's Avatar
    Jul 2005
    30
    465
    11 Post(s)
    @muhammad.irtiza
    Sir howcome the shock absorbers cause the engine knocking?
  17. #16
    ustaad_007's Avatar
    Jul 2005
    30
    465
    11 Post(s)
    @sd
    Did you use the Mukka Chowk TOTAL pump?
  18. #17
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    is there anyone else experienced more knocking after shifting to Zic A+?
  19. #18
    May 2014
    26
    117
    5 Post(s)
    @muhammad.irtiza
    I thought it was knocking with the ground.
  20. #19
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    @ustaad
    yup. muka chowk total pmp... i think ye badnam hai isi wja sey... thts y u caught it... and once i also used total pmp at highway after shell pmp to the right... xprnced sme issue...
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
  21. #20
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    check for thermostat valve in the cooling system. what about cooling fans & coolant ?? running direct on plain water in radiator? if its is FUEL issue it will always knock, - Thats a high engine temperature & timing advance which causes knock only during afternoon thats' when atmospheric heat is at peak too
    Hi,
    Is this the case ?
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
Tags for this Thread
