Results 1 to 19 of 19
Like Tree2Likes
  • 1 Post By choona_pk
  • 1 Post By Yasirshafeeq
Thread: Strange 'Tuk" sound from Vitz when brake is applied
    vitz_2006's Avatar
    Jul 2012
    108
    2 Post(s)
    Default Strange 'Tuk" sound from Vitz when brake is applied
    I am facing a strange "TUK" sound problem (mostly noticeable) with my Vitz 1.0 (2006) when brake is applied at normal/slow/fast speed.This sound comes from the front part of the car and comes only when brake is applied
    i have observed that this sound almost always comes (or noticeable) when car steering is 'slightly' turned left or right (90% of times whenever brake is applied in this mode) while it occasionally and sometimes frequently comes if car is moving straight.(50 -60 % of times whenever brake is applied in this mode)
    Any ideas what this sound is ? . (I have taken my car 2-3 times to different mechanics to diagnose the problem and strangely this sound does not appear during the test drive...frustrating !)
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3985 Post(s)
    93 Thread(s)
    6
    loose caliper?
    VCheng's Avatar
    May 2010
    Select City
    25,475
    7
    434 Post(s)
    4 Thread(s)
    Check the anti-rattle clips for the brake pads.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,578
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Exclamation
    goto some suspension shop and get the front shock absorbers checked, such 'TUK' is from cracked front suspension insulators aka upper shock mounts
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    vitz_2006's Avatar
    Jul 2012
    108
    2 Post(s)
    @capsat: If the tuk sound comes only when brake (even the very soft one) is applied, on the smooth roads too, then what does it have to do with shock thing?
    Can you please elaborate?
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Grease the caliper pins.
    The best car safety device is a rear-view mirror with a cop in it.
    maple's Avatar
    Apr 2013
    28
    177
    2 Post(s)
    i can answer better after checking not getting from what you are saying
    z_khan's Avatar
    Dec 2007
    30
    45
    5 Post(s)
    Quote Originally Posted by capsat View Post
    yes i agree , i was facing the same issue problem was cracked upper shock mount.
    http://www.pakwheels.com/forums/d-i-y-projects/271312-mercedes-benz-w124-1990-restoration-project-back-life
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,578
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Quote Originally Posted by vitz_2006 View Post
    TOP shock mount ( insulator ) when get a fracture for any reason, momentum of vehicle when restrained create single TUK sound due to lateral play in the insulator. be it highway or non-paved track
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    there might be play in caliper pin
    ahmed701's Avatar
    Jan 2011
    Rawalpindi
    96
    this same **** is happening with me also. the car is corolla 2012 model only 27000 km driven. i have got the braked caliper checked and pins greased. but the sound nevea comes during the test drive. i will go again to get it checked. one thing is sure the sound comes from front right wheel and seems as if the brake pades are hitting the edges of caliper of some bolt is loose. get ur right side shocks checked and caliper pins, brake shoes. see if the locks on both ends caliper corners are ok. some times loose clips are make sounds as the dics pads move back and forth on applying brakes.
  12. #12
    wolfkhan's Avatar
    Jun 2013
    Rawalpindi
    637
    18 Post(s)
    Name:  ImageUploadedByPW Forums1428695369.044272.jpg
    Can anyone plz tell whats the main difference of these grades or packages that comes in vitz? And which is the best package from all of the above in 1.0 vitz
  13. #13
    haiderjaved's Avatar
    Mar 2010
    32
    813
    26 Post(s)
    Seems to be the loose caliper or caliper pin. Let ue know when the sound is gone.
  14. #14
    Owais_Yunus's Avatar
    Sep 2005
    28
    2,224
    60 Post(s)
    Get the pads checked if they're sitting snugly with the shims. Cheap brake pads are often not exactly the same size as oem ones and upon braking, smaller pads may slide to one side due to the circular motion of the brakes and collide with the caliper before starting to function properly which could cause the 'TAK' sound. Mechanics also often fit the shims improperly or do not fit them altogether which would cause the brake pad to stay loose in the caliper.
  15. #15
    choona_pk's Avatar
    Feb 2010
    8
    Hi there,
    I also have vitz 2005 new shape, I used to get this Tuk sound from the front part of the car on breaking and also while changing the gear from R to D and D to R.
    Turns out that the axle was slipping or whatever you call it, changed the axle and the sound went away.
    @vitz_2006 is the issue resolved now, please let us know what was the cause. Thanks
  16. #16
    Yasirshafeeq's Avatar
    Nov 2012
    371
    3 Post(s)
    Tuk Sound is most probably due to worn out Boot of Suspension Rods, (With Axle a slim rod having two boots; one at upper terminal join and one at lower terminal joint). U can check it by lifting the car and see from under the car, Small boots with leaked Grease in musard colour. Toyota Ravi Motors guy showed it to me in my 2006 vitz (2011 Import). I think same is urs problem. Tuk sound is not due to brakes normally. Brakes have other sound issues.
    Never underEstimate anyone. Might be a charade has a v8 in his heart.
  17. #17
    tintin1's Avatar
    Jan 2014
    1,828
    7
    61 Post(s)
    2 Thread(s)
    7
    Quote Originally Posted by wolfkhan View Post
    put this question on Vitz Fan club and hope you will get the answers.
    Usually the difference is not very big. Some seats are slightly different, some has back viper, some has little wide bonnet, some has 8 airbags, some has only 2, etc. thats why they give different name to each model.
    But engine is same 1KR-FE.
    Here we have to choose among the models which are available here. Because no one cares to see these details before importing vitz.
    Be Addicted To Help Others.
  18. #18
    tintin1's Avatar
    Jan 2014
    1,828
    7
    61 Post(s)
    2 Thread(s)
    7
    This is the play in the main axle.
    Either spend few thousands and have it change to new one. As per post 15 of this thread. am sure it will cost more than 10K.
    Or you can keep it ignoring but surely not for the long time.
  19. #19
    gitts070's Avatar
    Jul 2010
    36
    510
    14 Post(s)
    Quote Originally Posted by ahmed701 View Post
    Has your problem been solved, just wanna to know cause am facing the same.
    thx
