Results 1 to 14 of 14
Thread: Vitz 2007 Jerks whien applying break and release to accelrate!
    obsession.mind.9's Avatar
    Jul 2013
    31
    12
    Unhappy Vitz 2007 Jerks whien applying break and release to accelrate!
    Aoa,
    I have some problem with my ride when I apply brake in my Toyota Vitz 2007 and release the break, it feels like some invisible brake is still applied. If I do not accelerate after releasing break, the car jerks after some time as if the invisibly applied break is removed. This does not happen every time but some days this happens more frequently.
    I thought this could be a transmission problem and changed transmission fluid, Engine Oil change, Air Filter, Throttle body clean, break service, NGK laser spark plugs even with Hi-Octane refill (as i always use to add some). At first i thought it solved the problem but issue still exists.
    What could be wrong with my car? Your help is highly appreciated
    Thanks
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    A common problem with Vitz, time to check your Cat Converter, whats the mileage ?
    does your car vibrate on idle or D?
    Laws r Made to be Broken
    waleed2409's Avatar
    Feb 2015
    62
    I think these cars r designed to sense tht brakes are applied so when u release the brake the brakes r release but if u notice the rpm reeves up a little. So as to control the speed with transmission. (Same science when u drive in low gear in manual transmission on slopes).
    My vitz 2006 does the same. It keeps the car in controlled deceleration even after the brakes are released.
    But tht shud not give jerks. Mine gives a v v v minute jerk smtymes.
    Jul 2013
    31
    12
    Hi Muradi,
    Dear there's no catalytic converter.Unfortunately, it was removed by Toyota Mechanic which is not recommended.Mileage is up to 72,000 and yes it vibrates on D sometimes.
    Thanks
    Jul 2013
    31
    12
    Dear Waleed,
    It was never before so it starts doing this.
    Thanks
    Quote Originally Posted by waleed2409 View Post
    fahad.palijo's Avatar
    May 2013
    5
    just check your torque rod & engine mount and lemme know im sure is those thing 03368256698
    Jul 2013
    31
    12
    Bro i have diagnosed all mounting and they are perfect but I notice when i don't add Hi-Oct then there are too many jerks.Secondly, my vitz vibrates when i steer, pressing horn, opening/closing windows/mirrors.I don't know what's wrong with it. May be Battery issue? Electrifier weaken? Because, i have installed HIDs, Sound System with AGS 65 AMP wet battery around 6,7 months old.
    Please let me know
    Thanks
    asadilyas.acca's Avatar
    Feb 2015
    Peshawar
    24
    46
    3 Post(s)
    Quote Originally Posted by obsession.mind.9 View Post
    Please let me know
    Thanks
    Check your auto choke & sensor, how is the starting in the morning? If not smooth you should check tappets. By the way CNG installed?
    Jul 2013
    31
    12
    @asadilyas.acca
    Thanks for your reply.Nope, only petrol.You know one thing i couldn't find any Tech-y Mechanic who can diagnose it properly.Only they know about clearing errors through Scanner and some other crap about checking things here and there
    Even i have tried Dry Bosch,Hankook,ACdelco all batteries + Generator is also fine with electrifiers.
    Can you please suggest me any expert mechanic in Lahore?
    That would be great and much appreciated.
    Thanks
    Feb 2015
    Peshawar
    24
    46
    3 Post(s)
    @asadilyas.acca
    Thanks
    Bro I wish you were in Peshawar, I would have suggested you some good mechanics, anyhow why don't you check the tappets? Sometimes due to dust and other particles tappets and camshafts goes out of alignment that disturb the timing as well. I think that might be tappet problem. How is the starting in morning?
    ashbal's Avatar
    Sep 2006
    22
    2,081
    26 Post(s)
    just live with this low rpm issue...my vitz use to do it and getting rid of this problem was a hectic so i just stopped with it....anything electir when used it drops the rpm as if the engine is getting load....and it started happening after i got a new battery and ecu got reset due to that and after that it remained the same until i sold it
    M @ c!v!c '95 L0v3&
  12. #12
    Jul 2013
    31
    12
    Asad, starting in morning is normal but when you place gear position to D then it starts doing this.Recently, i just met with an experienced mechanic.He said, timing foundation is weak and fuel injectors need to check by Lab etc.
    Still confused
    Thanks
    Quote Originally Posted by asadilyas.acca View Post
  13. #13
    Jul 2013
    31
    12
    Asad can you please share your contact detail(Cell, skype,gmail)?
    Thanks
  14. #14
    Feb 2015
    Peshawar
    24
    46
    3 Post(s)
    Thanks
    03459043779
