Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Like Tree4Likes
Thread: vitz 2006 FL 1.3L, 2SZ engine problems.
    waleed2409's Avatar
    Feb 2015
    62
    Unhappy vitz 2006 FL 1.3L, 2SZ engine problems.
    hi guys i just bought vitz 2006 1.3 FL. i m observing 2 types of noise from the engine n i cnt get my mind off it as i m v choosy in these matters.
    1... at idle RPM the car produces some noise as if theres some thing in metalic box clinking while rotating ( dnt know how to explain the noise ) its v minute noise but still i want to get to the bottom of it. it only comes at idle RPM and if u remove the belt it goes away so it means its not engine noise its comming from the accesorries the belt drives.
    2... when i accelarate from idle to 2000 rpm or above the engine produces chir chir sound (its more like a mixture of knocking and loose belt noise combined) but it only comes between 1500-2000 RPM not lower than tht and not higher thn tht.
    help wud b highly appreciated
    redards
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    I think i read here someone saying waterbody was the culprit on the forum for similar complain
    waleed2409's Avatar
    Feb 2015
    62
    I replaced waterbody but to no avail. I think the sound subsided fr a little while but again ce back. Also i inspected the waterbody head n it seemed fine
    waleed2409's Avatar
    Feb 2015
    62
    No help???
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    Did u tighten up the belt?
    Laws r Made to be Broken
    waleed2409's Avatar
    Feb 2015
    62
    The noise was thr when i bought the car abt a month back. N i took it to mechenic he removed the belt n the noise went away. But he was unable to diagnose the problem so had to put the belt back in.
    waleed2409's Avatar
    Feb 2015
    62
    Its not the noise of loose belt thts for sure
    waleed2409's Avatar
    Feb 2015
    62
    @Xulfiqar bhai plz help
    imrananr's Avatar
    Jun 2014
    845
    5
    19 Post(s)
    Quote Originally Posted by waleed2409 View Post
    redards
    I have replied to you in another thread, in which you have also informed that it goes away when A/C compressor is ON. I have suggested you that the A/C compressor clutch pulley bearing assembly is the culprit. Replace the complete assembly.
    Don't leave a highway for a byway....
    waleed2409's Avatar
    Feb 2015
    62
    But then y it goes away if the car is in S or N or parking mode?
    waleed2409's Avatar
    Feb 2015
    62
    Ok sory disregard my last msg. Mixed up the two sounds.
    Ok thnx a lot bro wil check it out n let u knw soon. Hope it goes away.
    Thnx once again.
  12. #12
    waleed2409's Avatar
    Feb 2015
    62
    I have replied on that thread. If possible u cn reply to my querries here so as to avoid clutter on tht thread.
    Thnxx
  13. #13
    waleed2409's Avatar
    Feb 2015
    62
  14. #14
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,596
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    which city you are located - in Lahore contact @syncview
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  15. #15
    waleed2409's Avatar
    Feb 2015
    62
    I m in abbottabad. But i can go to islmabad or pindi
  16. #16
    waleed2409's Avatar
    Feb 2015
    62
    Or if syncview comes highly recommended i can even go to lahore just for this matter.
  17. #17
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,596
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    before you head out, ask your mechanic to use hose-steathoscope method to isolate the problem, in this a small length of garden hose is used with 1 end to the ear & other end moved around in engine bay to listen to possible location of noise emission. Most likely it seems the problem of aircon idler pulley bearing or the aircon clutch bearing ... or may be ... the generator belt completed its life
    @Xulfiqar , @margallar
  18. #18
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    you need a proper automotive stethoscope to identify the source of noise
    https://www.facebook.com/OsamaAbbasPhotography
  19. #19
    waleed2409's Avatar
    Feb 2015
    62
    Quote Originally Posted by syncview View Post
    My mechenic tried to identify the source with the stethoscope. But he was unable. N hes a fairly good mechanic. I wil try to do it myself n get back to u guys with results.
    Plx stay here n help me out till i resolve the problems. Help is much apreciated.
    Regards.
  20. #20
    tjcivilian's Avatar
    May 2011
    Peshawar
    31
    235
    2 Post(s)
    I think its due to the loosing of crankshaft... you might need to polish it. I had already passed through the same situation on 2009 model 1.8 altis.
    I couldn't repair my breaks, so I made my horn louder...
