Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By Uashah007
  • 1 Post By fouadbakht
Thread: Toyota vitz 2010 bettery replacement
    bashair's Avatar
    Mar 2013
    Default Toyota vitz 2010 bettery replacement
    AOA
    I have toyota vitz 2010 model its battery is not working properly , i want to replace that bettery can anyone tell which battery i should purchase for toyota vitz ?
    Uashah007's Avatar
    Mar 2011
    Peshawar
    309
    8 Post(s)
    Bro go for hankook dry battery. I am using same battery from two years, no problem at all.. it will be bit costly as compare to other batteries... but worth it every penny.
    scorpiono1's Avatar
    Jun 2013
    50
    Quote Originally Posted by Uashah007 View Post
    from where i can get this battery and installing also..
    fouadbakht's Avatar
    May 2006
    3,620
    20
    140 Post(s)
    Its about time you switched to maintenance-free battery aka dry battery. I've personally tried Hankook and can vouch for its quality and reliability. Just a word of advice: Try to get the max juice battery in any particular/ given size. It will help you in the long run.
    Sent from my iPhone 6 Plus using PW Forums
    https://www.facebook.com/hidefcars
    Uashah007's Avatar
    Mar 2011
    Peshawar
    309
    8 Post(s)
    Quote Originally Posted by scorpiono1 View Post
    U can get it from any good battery shop at your respective city..
    your location ...
    scorpiono1's Avatar
    Jun 2013
    50
    your location ...
    I am in karachi
