Results 1 to 5 of 5
Thread: Vitz airbag light on .
    Drifter_ali's Avatar
    Mar 2009
    Neijiang
    28
    123
    Exclamation Vitz airbag light on .
    salam .
    Friends I have Toyota Vitz 2009 Model, Today morning when i start my car after that there is Airbag sign on .and its still there I don't know what to do with it , should I checked it with computer scanner ?
    any suggestion will be highly appreciated.
    Thanks in advance
    ahzaaz's Avatar
    Jun 2009
    38
    2,868
    21 Post(s)
    W/s.
    Please mention if your horn is working or not?
    If the horn is not working too, then airbag strip component is out of order. (strip broken)
    Vitz airbag light on  -1540031This component has to be replaced if the horn is not working too
    Vitz airbag light on  -1540032
    Please mention if you've recently get you tire aligned as well.
    Thanks
    Bid Me Run & I Will Strive With Things Impossible - 4x4 The Madventure
    Mar 2009
    Neijiang
    28
    123
    thanks for your reply, yes Horn is working fine. only airbag light is on..
    m.raheel's Avatar
    Feb 2015
    23
    Bhai jo bl rahy hai wo theek bol rahy hain ap is clock spring ko chack karwalyn
    m.raheel's Avatar
    Feb 2015
    23
    Passenger set k nechy 2 pin sokit hoga yellow clur ka wo chack karlyaga
Tags for this Thread
