Results 1 to 3 of 3
Thread: Vitz not picking up Power/ lost power
    hammadsiddiqui1976's Avatar
    Jul 2010
    244
    3 Post(s)
    Default Vitz not picking up Power/ lost power
    First there was no signal at all, i have changed the battery which was dead, because my car was parked for the last 04 months and was not in used.
    second i have also changed one fuse.
    after changing battery and fuse my car starts but when i pressed accelerator she did not pick speed (NO RPM) (NO RACE) car is running only IDLE condition.
    Kindly help (its Vitz 2009).
    tanzeel5's Avatar
    Dec 2011
    20
    @hammadsiddiqui1976
    Sir, In these cars the acceleration, gear changing and many other things are controlled by Electronic circuit.
    It is possible that u could have changed a wrong fuse or maybe there is a difference in ratings. Get it checked by a Toyota Authorized Dealer. Hope it helps =D
    shadab_lodhi's Avatar
    Feb 2012
    Rawalpindi
    82
    Check and replace the red colored 10 amp fuse named ECTS located in the fuse box in the engine compartment.
