Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By shan85
Thread: Vitz 2011 (new shape) tyre and rims suggestion
    shan85's Avatar
    Jan 2014
    55
    Default Vitz 2011 (new shape) tyre and rims suggestion
    Can anyone suggest tyre size and rims for vitz 2011 (new shape) to increase fuel average ,road grip and height. In case of height will i loose the comfort zone ? Kindly advice
    Sent from my iPhone using PW Forums mobile app
    mirpk1's Avatar
    Jan 2015
    537
    8 Post(s)
    simply adopt the company suggested sizes and most impotently air pressures of tyres (which are 36 front 34 back not 28/30 suggested by tyre walas) .. every thing will be fine
    shan85's Avatar
    Jan 2014
    55
    Quote Originally Posted by mirpk1 View Post
    Thanks
    fouadbakht's Avatar
    May 2006
    3,620
    20
    140 Post(s)
    No not that. Just messing around. Good advice though
    https://www.facebook.com/hidefcars
    shan85's Avatar
    Jan 2014
    55
    R u sure ? Bcz 36 and 34 seems too much. I dont think it can reach to the comfort level with this air pressure.
    khalid7shafqat's Avatar
    Sep 2014
    24
    1,006
    18 Post(s)
    Quote Originally Posted by shan85 View Post
    For best mileage and comfort, Go for company recommended tyre size.
    For height issues, u need to get your car raised, no other way about it.
    Tyre pressure depends on you
    Goodluck !
    mirpk1's Avatar
    Jan 2015
    537
    8 Post(s)
    Edit..
    mirpk1's Avatar
    Jan 2015
    537
    8 Post(s)
    Quote Originally Posted by fouadbakht View Post
    Typo error makes a difference
    KhurrumIftikhar1's Avatar
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    Best size for vitz in 14 inch rim is
    185/65 r14
    2nd will be
    175/70 r14.
    And in 15 inch rim
    Best will be
    175/65 r15 which is of new city
    Or
    185/60 r15 which comes in swift.
    These sizes are available in market of good brands like michlen, yoki advan db, bridgestone.
    Also there height is almost same as
    165/70 r14 which is height.
    Remember that height of tyre effects the performance and comfort of car.While width if in certain limit like 185 for city , swift, and vitz is good for high speed handling
    shan85's Avatar
    Jan 2014
    55
    Quote Originally Posted by KhurrumIftikhar1 View Post
    185/65 r14
    2nd will be
    175/70 r14.
    And in 15 inch rim
    Best will be
    Or
    Then how about the air pressures? 36 in front 34 in back ? Or some body told me 28 in all?
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    When you increase the tyre size the tyre air pressure recommendation chandes
    Eg if you adopt 185/65 r14
    It is awide tyre and more air is volume of air is needed to build pressure. Thus there will be a great variation in air pressure with temp.
    Since recommend is 36 in front 34 in back
    You increase tire width thus decrease 4 psi
    Also taking pakistani road conditions in consideration decrease more 4 psi
    Now you should have 28 in front 26 in back best presaure
  12. #12
    03430212013's Avatar
    Feb 2015
    21
    135
    Sir help me plz, chevorlet joy ki rims pcd kia hai.. does 110 pcd rims can be placed? Yes Or No.
