Results 1 to 14 of 14
Like Tree5Likes
  • 1 Post By car_bus2008
  • 2 Post By Xulfiqar
  • 1 Post By Owais_Yunus
  • 1 Post By aomair
Thread: My new Vitz ECU problem
    KhurrumIftikhar1's Avatar
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    Default My new Vitz ECU problem
    Althoug it is extensive but please read it.
    Salam
    I Bought Vitz 2013 3rd gen 1.0 krfe intelligent package.
    Car has factory installed fog lights wiring but no foglights.
    I went to a shop to install fog lights.
    He installed the fog lights to orignal wirring but fog lights dont turn on.
    Although the wiring till fog lights buttons respond .i.e button light turns on when headlight is turned on but fog lights dont.
    Then after many attempts he install wiring that comes with fog lights upto fuse box below glove box. And
    Fog lights turn on.
    But when i started the car the ecu turned following lights on.
    Check engine light.
    Abs light
    Break Light.
    On
    OBD scanning following errors show.
    1.Rear right speed sensor
    2.Check or Short RH sensor circuit.
    3.Ambiant Temp sensor.
    What could possibly the reason
    Do any of you faced problem.
    Please guide me my car is Applied for 2015.
    car_bus2008's Avatar
    Jan 2008
    1,770
    23 Post(s)
    2 Thread(s)
    their might be some type of short.Tell the electrician to put each and every wire back and forget fog lights.
    Money differs from an automobile or mistress in being equally important to those who have it and those who do not.
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    Thanks i am going to do that
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    But what after that
    ahsanonline's Avatar
    Jan 2007
    Rawalpindi
    86
    2,295
    19 Post(s)
    3 Thread(s)
    If the codes weren't there before messing about with the distribution box, then some wires may have gotten loose or a break might have developed internally. Could be a host of different reasons but I'd go with checking and making sure all connections are sturdy.
    As for original fog-light wiring, does it go up to the bumper area where the lights are supposed to be installed? If not then it might just be a signal wire for a fog-light relay, which then gives bijli to the fogs just like a headlight relay does for the headlights. Either way he should've just used a relay and taken the fogs-on signal from the existing harness without disturbing the main distribution box.
    Selling Vitz+local cars - compatible bluetooth Ecu Scantool, High-amp car chargers, Apple-certified Lightning Cables, etc. Click on my name and see my started threads for details.
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    I go to him asked him to remove fog light wiring.
    He removed and gave it direct connection with headlights.
    And also remove each and every wire but problem still there.
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    But i remember he did not remove fuse of fog lights should i remove it.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    you cannot simply slap on fog lights and expect them to light up in these new cars. But now that your "elektrishann" has messed around and got you some nice error codes shining at you.
    Get him to fix em - you took the car to him for a job, his attempts have messed it up - he should repair it.
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    There are two fuses
    Fog fr
    Fog rr
    What are they for
    m.raheel's Avatar
    Feb 2015
    23
    Bhai Jan ecu refresh karwaly wires agaya hai
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    Quote Originally Posted by m.raheel View Post
    Sorry
    I Don't understand?
  12. #12
    Owais_Yunus's Avatar
    Sep 2005
    28
    2,224
    60 Post(s)
    While connecting the fog lamps, the electrician may have taken off some grips with the ignition switch on, which could've generated error codes and they might've been stored in the ecu and are showing up on the check engine light. You could first reset the ecu by taking off the negative terminal of the battery for a few seconds and then putting it back on and see if that clears the codes. If the codes are still there, he must have messed with the wiring or used incorrect polarity somewhere, causing a short circuit or burning something. If the electrician is useless enough to do such a thing when just connecting the fog lamps, I'd recommend you not to take it back to him to fix it as he could cause further harm to it. However, you may coerce him into coughing up the damage that he has done.
  13. #13
    Thinking's Avatar
    Jul 2008
    34
    2,305
    62 Post(s)
    get a ecu reset.
    ask your electrician to get the car fuse box and switches and wires exactly in the previous situation again.
    verify if the codes go away.
  14. 25-03-2015, 03:18 PM
    PakWheeler
  15. 25-03-2015, 06:42 PM
    Senior PakWheeler
  16. #14
    aomair's Avatar
    Apr 2005
    576
    Common problem with most of JDMs. The original "damaged" bumper might have the fog lights installed but while getting it repaired here at local workshop, simple bumper is installed and painted. The wiring remain intact as the mistri might not aware of what to do with that, else it would be removed too.
    These JDMs cars are sensitive and they should have be kept miles away from these auto shops which are owned and run by people who can only repair old Corollas and Suzukis.
    Change of faces won't change anything in Pakistan. www.greenwood.pk
