Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Whistling/chirping noise from Timing belt area of Vitz 2005
    usmankpk's Avatar
    Jun 2014
    29
    104
    Default Whistling/chirping noise from Timing belt area of Vitz 2005
    Hello PW's,
    I recently bought a Vitz 2005 milage: 75,000km. The person I got it from had recently done full service etc from Toyota 3S Rawal motors. Having driven the car now 5,000km (milage: 80,000) I am facing the following 2 issues:
    Requesting your guidance and suggestion on what to do:
    1) When the car is on idle there is no Whistling/chirping sound, but as soon as I put it on D and drive no matter what speed the Whistling/chirping sound comes up. Although when I accelerate at higher speeds(above 100km/h) the sound goes away. I took the car to Toyota 3s dealership on rawal road and the mechanic there said its the timing belt(belt rolled around the bearings). I said fine went back in asked how much for the belt and they actually said 8,000 Rs for the "original imported from Japan"??? Then there was another option which was mentioned by Toyota service reps that I can get one which is also original but used that I can get for half the price i.e. Rs 4,000!!!?!? Seriously is it me or this is the actual price of a belt??? Is there other shops nearby Rawalpindi from where I can get a BELT for my car at a reasonable price??? At this point I am not even sure that a new belt would sort the noise issue?
    2) I noticed just 2 days ago that when I accelerate, the car seems to be reving the RPM BUT the speed is not up to the par. I hear more engine rev noise and the car's speed is not up to the same mark. The RPM and speed are not inline as they were 2 days back.
    Please help! Your suggestions dearly needed. Thanks!
    P.S I havent done anything so far to the car in terms of servicing etc.
  2. #21
    Proverbial_Slang's Avatar
    May 2005
    3,904
    29 Post(s)
    Quote Originally Posted by usmankpk View Post
    Ok that outer axle is it also known as "kit" in local terms? Because the second mechanic said the IT needs replacement. Shoul I get the Chinese or kabuli one?
    No gurantee of Kabli. I never had godd experience with Kabli axles.
    Get good quality "Japanese" ones. They call it japaani but are also chinese. Don't go for cheap chinese ones.
    Sent using Curiosity's onboard communications sytem.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  3. #22
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    good quality Chinese one but make sure to buy branded good quality cvj (axle) grease some Chinese CVJ come with very pathetic grease about Qabli (kabuli) there are either stolen part or repaired one so stay away from Qabli parts
