Results 1 to 6 of 6
Thread: How to do engine wash/details of Vitz 1000cc 1KR-FE engine
    usmankpk's Avatar
    Jun 2014
    29
    104
    Default How to do engine wash/details of Vitz 1000cc 1KR-FE engine
    Hi Members, Uptill now I haven't tried to clean engine bay area fr my Vitz. I believe the time has come now to get it cleaned as its all dust & sandy from under the hood and in the engine bay area. Please specify the right way to go about it should I just take my car to a particular service stop where they do cleaning with a pressure hose etc? Is it ok to spray water from a hose to the engine bay area or any specific way of doing??
    usmankpk's Avatar
    Jun 2014
    29
    104
    Default How to do engine wash/detailing of Vitz 1000cc 1KR-FE engine bay/area
    usmankpk's Avatar
    Jun 2014
    29
    104
    Bump
    imrananr's Avatar
    Jun 2014
    845
    5
    19 Post(s)
    Quote Originally Posted by usmankpk View Post
    Well you can use the following:
    1) Use air pressure hose to blow off dust throughly over and around the engine. (Get it done throughly giving enough time).
    2) Spray engine and bay cleaning FOAM all over the engine and let it soak all the dirt and drip out.
    3) Repeat step 2 once again (depending on how dirty the engine is).
    4) Spray water jet at the periphery of the engine bay (car body only).
    5) Use clean dry cloth to wipe off the entire engine, related auxiliaries and engine bay.
    Note: No water is sprayed on the engine and related auxiliaries.
    Don't leave a highway for a byway....
    usmankpk's Avatar
    Jun 2014
    29
    104
    Quote Originally Posted by imrananr View Post
    If I cover certain parts with foil under the hood even then I cant spray water? You mentioned FOAM any specific for doing what you advised?
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,959
    32 Post(s)
    use plastic bags to cover up electrical components
    you can use a spray gun(used for spraying insecticides) or a garden hose to rinse the engine just dont over do it
    then use a engine cleaning product (astonish is good and cheap) just spray it and agitate using a brush or a shampoo solution would work too
    rinse again and your done
    also if you have blower then its makes drying and getting water out of hard to reach places easy
