Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By alee_k
  • 1 Post By alee_k
Thread: Ecu re-learn procedure?
    alee_k's Avatar
    Dec 2010
    Hyderabad
    412
    4 Post(s)
    Default Ecu re-learn procedure?
    I've vitz 2011, It started vibrating after battery change, can anyone let me know ecu re-learn procedure?
    Click here for SOLUTION
    |e.X.t.r.e.m.i.s.t.s| War Till Death
    mir.azam's Avatar
    Nov 2014
    22
    289
    6 Post(s)
    I asked same thing from the dealership guy that if battery is replaced what happens as ecu resets, he told me that "we have to redo the process of ecu learning."
    Now you have to take your car to "Toyota Hyderabad Motors".
    alee_k's Avatar
    Dec 2010
    Hyderabad
    412
    4 Post(s)
    Toyota will charge alot for this :/
    HellsGuardian's Avatar
    Nov 2007
    26
    2,202
    84 Post(s)
    4 Thread(s)
    Not sure about vitz but here is the civic's procedure. Replacing battery resets the ecu, the rough idle is probably because either the engine was cold afterwards or you kept revving it.
    1. Heat up the engine until fan turns on (keep rpm between 2.5-3.5k if you want it to reach operating temperature quickly), i ran it 1 more min afterwards.
    2. Turn the car off completely.
    4. Remove fuse or battery (i removed battery negative) and wait 1-2minutes
    5. Make sure there is no load on engine (no lights, ac, blower anything at all) and reconnect the battery
    6. Start the car and let it idle for 10mins.
    7. Turn off the car and wait 2minutes.
    8. Start the car and drive normally. Step 8 confirmed that the unstable idle is fixed.
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Just drive it around. It will be fine after some time. self learning works with these ecu.
    Keep a cool head and wear seatbelts!
    alee_k's Avatar
    Dec 2010
    Hyderabad
    412
    4 Post(s)
    I've driven like 200km, it still vibrates :/
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Ecu re-learn procedure? - 1537551 vitz 2007 jerks whien applying break release accelerate 1418294304071
    alee_k's Avatar
    Dec 2010
    Hyderabad
    412
    4 Post(s)
    Quote Originally Posted by saboor73 View Post
    Thankyou, It worked
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    The idle relearn calibration is done with toyota scan tool only it needs throttle re learning and you will be done any other procedure are not valid for the toyota new 1kr series engine's introduced in 2011.
    Idle relearn is only done if the previous leaned settings are erased by scan tool. Only changing batteries dont effect the idle relearn calibration.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    by re-learn do you mean re-mapping ? does it not happen automatically when 'RESET' [removing battery terminal(s) over night ] is performed?
    supplementary question how about if an ECU from scrap does not match the engine for version difference. Can it be downgraded to a previous version, remapping via an OEM scanner. i.e Honda, Toyota, Suzuki, Mitsubishi
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    vickybhai's Avatar
    Aug 2005
    26
    2,448
    38 Post(s)
    Does the ON means starting or keeping the key to ON position???
    1)Suzuki Mehran has changed its shape 2)Fake parts drive me nuts
    3)https://www.facebook.com/RoyaleEM
