Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Like Tree3Likes
Thread: Recommended oil for Vitz 2001 AT
    realinlife's Avatar
    Mar 2014
    33
    3 Post(s)
    Default Recommended oil for Vitz 2001 AT
    Please guys, I need to change soon as it has been quite some time since the last change [which I didn't] and I believe the last change was of Shell or ZIC [The one in yellow] 10-40.
    Mileage is around 130,000 and I think I also should change the gear oil
    FaatehRehman's Avatar
    Apr 2010
    Rawalpindi
    25
    222
    5W-30 oil of your trusted brand.
    I personally use Shell Blue Box.
    realinlife's Avatar
    Mar 2014
    33
    3 Post(s)
    please consider the mileage of car engine too and would it be ok to go directly to 0-30
    Leo_The_King's Avatar
    Jul 2013
    30
    101
    2 Post(s)
    Sir its a bit old engine and u have to use thick oil (20w-50)... Zic A
    tintin1's Avatar
    Jan 2014
    1,841
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by realinlife View Post
    Any idea about engine.
    its 1KR-FE or 2NZ-FE?
    Any leakage or smoke? Oil reduction, Water reduction, etc. etc.
    by the way, the ZIC yellow bottle is 20w-50
    Be Addicted To Help Others.
    realinlife's Avatar
    Mar 2014
    33
    3 Post(s)
    The one I had, said gasoline oil.
    And the engine is 3 cylinder so I guess it's KR-FE. Engine looks to be perfectly fine to me. Car is in good condition.
    tintin1's Avatar
    Jan 2014
    1,841
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    If engine is good, then try 5w-30 for best fuel economy. You can change after 5K.
    But first time, change it after 3~4K only.
    realinlife's Avatar
    Mar 2014
    33
    3 Post(s)
    which one do you recommend? Kixx?
    omer.s's Avatar
    Sep 2010
    30
    590
    13 Post(s)
    Kixx is also good or you can use shell and liquimoly
    Apr 2010
    Rawalpindi
    25
    222
    1 KR-FE comes in 2nd generation Vitz onward.
    In 2001 Vitz 1SZ-FE is the factory fitted engine. It is 4 cylinder
    omer.s's Avatar
    Sep 2010
    30
    590
    13 Post(s)
    Quote Originally Posted by FaatehRehman View Post
    Exactly thats what i was about to say
  12. #12
    realinlife's Avatar
    Mar 2014
    33
    3 Post(s)
    Well, I took out the car documents which I have and the registry says 3 cylinder. It was brought to Pakistan in 2007..
  13. #13
    omer.s's Avatar
    Sep 2010
    30
    590
    13 Post(s)
    Plz post a pic of your car's engine bay
  14. #14
    tintin1's Avatar
    Jan 2014
    1,841
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    How many spark plugs it has ?
  15. #15
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,959
    32 Post(s)
    there must be some error in the documents
    all 1st gen Vitz had 4 cyl. engines
  16. #16
    realinlife's Avatar
    Mar 2014
    33
    3 Post(s)
    I guess there is an error in documents. the engine is SZ-FE, I saw the pics of the engine and I figured it out. Plus, there are four gears when the o/d is on so that must be an indication too.
  17. #17
    realinlife's Avatar
    Mar 2014
    33
    3 Post(s)
    could you guys quickly tell me? I called my mechanic and he recommended 20-50 because summers are coming and engine is old :\
  18. #18
    ZainMahdi's Avatar
    Dec 2012
    22
    928
    50 Post(s)
    Mineral: Caltex Havoline 10w-30 SM
    Semi-synthetic: Shell HX-7 5w-30 SN
    Synthetic: Zic Ow 0w-30 SN
    Take your pick; all of these are good for your car. There is no harm using a 30 weight oil in a 130k km driven car; that is mileage is nothing, especially if the car has been periodically maintained.
    _ 22 km/l from '03 VTi automatic, with plenty of room for improvement
    _ How to hypermile: http://www.cleanmpg.com/community/index.php?threads/1510/
  19. #19
    realinlife's Avatar
    Mar 2014
    33
    3 Post(s)
    Going full synthetic would be a bad idea in summers, no?
  20. #20
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,959
    32 Post(s)
    why would it be ? dont listen to everything your mechanic says
    he might have also suggested to make the cooling fans direct and remove the thermostat valve because "woh thandy elakon k liye hy"
    Synthetic oils are better at resisting heat then mineral oils
    Toyota has recommended 5w30 semi or fully synthetic oil for your car
