Results 1 to 15 of 15
Thread: 2006 Toyota Vitz engine vibration
    toohoking's Avatar
    May 2015
    Auckland
    Smile 2006 Toyota Vitz engine vibration
    Hi, I am owning a vitz (1.0L Automatic petrol) with a mileage of 103,XXX KMs. I bought it in last July and had no clue about its mantainance history. About 2 month ago, the engine started shaking when idle. But when the speed comes over 40km/h, it turns out to be OK. Besides, the vibration becomes more serious when the wipers are working. Can anybody give me a suggestion to fix this problem?
    PS: I come from China, hope my poor English not make you confused. I googled such problem seeking for a solution and found this awesome forum. I've read a few threads in this forum discribing the same issue and bulid a fuzzy clue that possible reasons may be from engine mount, throttle body or MAF. Which one is applicable to my scenario? I hope this thread could help others with the same problem. Cheers!
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    @toohoking welcome to PAKWHEELS, there is another chinese-mangol-punjabi respectable administrator among us @ VCHENG he can help you too to translate mandarin, mangolian, cantonese to english
    anyway mate you have worded your problem in english very well, please stay with us. following are likely causes of such problem tagged are other PRO solvers @syncview, @rustam54 @argtr65 @SER_GTR @Xulfiqar
    I suggest inspection of :
    1. engine mounts
    2. bad ground between frame & generator / battery ground pole to frame & body [ wiper motor takes load too ]
    3. transmission mounts
    TB & MF malfunction will cause bad fuel consumption & loss of power, - am sure others will also offer their input -
    BTW a/t need fluid & fluid filter change every 75000 kms, if there is no history available, Please change now,
    Quote Originally Posted by toohoking View Post
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Welcome To Our Pakistani Forums ...We Welcomes CHinese Friend
    Mention Your Vitz Model For More Understanding
    Anyways Get Your Engine Mounts Checked And Ground Checked...They Seems Broken As Vibration Can Be Felt Due To That Also
    Also Make Sure There Are No Lame Connections Done...Wiring...That Might DIsturb Electrical System And Cause Engine To Act Lame..
    For Rough Poor Idle....Get You Throttle Body Cleaned And CHeck Your Idle Air Valve..That Might Be Jamnned Causing Rough Idle So As Dirty Throttle Body
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    Quote Originally Posted by SER_GTR View Post
    where idle air valve is located ?
    toohoking's Avatar
    May 2015
    Auckland
    Thanks so much, my friend. I will check with the mechanician and keep this thread updated.
    toohoking's Avatar
    May 2015
    Auckland
    The model is DBA-KSP90. Thanks for your input, my friend.
    ecu_designer's Avatar
    Nov 2013
    255
    21 Post(s)
    Vitz 1.0L CVT 1KR-FE has no Idle Air Valve, its equipped with ETCS. I hope cleaning the throttle body will resolve the rough idle problem.
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    @toohoking,
    1- Check and replace spark plugs.
    2- Clean / replace air filter.
    3- Clean throttle body & as well as check butterfly valve for worn out,replace throttle body in case of worn butterfly valve.
    4- Check vacuum pipes for proper connection.
    5- Make sure all electrical wiring connecter firmly connected on there specific location.
    Never loose hope in life,every step gives u something.
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Quote Originally Posted by ecu_designer View Post
    I Thought He Got One With 1SZ-FED...Didn't Notice 2006
    In 1KR. Idle Is Usually Solved By Cleaning Throttle Body....Much Common In These Motors...Butterfly Usually Get Stuck With Moisture Dust Deposit And Cause Unstable Idle
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Quote Originally Posted by MADDYBOY View Post
    In 1KR Can Be Resolved By Clean T.B
    In 1SZ...Its Located Somewhere On Right Side Below Your Intake Manifold
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    1KR = 1.0
    if i am not wrong
    can you share the pic as i am not getting what you are trying to make me understand if possible
  12. #12
    Nov 2013
    255
    21 Post(s)
    1KR = 1.0
    if i am not wrong
    Vitz Variants (XP90 2005 to 2010)
    1KR-FE I3 ==> 1.0L CVT 2WD (ETCS)
    2SZ-FE I4 ==> 1.3L CVT 2WD (ETCS)
    2NZ-FE I4 ==> 1.3L AT/MT 4WD
    1NZ-FE I4 ==> 1.5L AT/MT
  13. #13
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    exactly
    i am asking where idle air valve is located with reference with pic
  14. #14
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    1KR = 1.0
    if i am not wrong
    1SZ Comes In 1999-2004 Whereas 1KR Comes 2005-2010
    Both 1.0L...
    1KR Don't Have It...
  15. #15
    toohoking's Avatar
    May 2015
    Auckland
    Yes, I think my model should be 1KR-FE I3. Thansk ecu_designer.
