Results 1 to 7 of 7
Like Tree3Likes
  • 2 Post By siliconbwp
  • 1 Post By tintin1
Thread: Toyota Vitz 2005
    siliconbwp's Avatar
    Feb 2015
    Bahawalpur
    28
    9
    Default Toyota Vitz 2005 error P0722
    Toyota Vitz 2005 import 2008
    i am receiving error P0722
    i changed the speed sensor but still the same
    when car cross 30KM speed on speedo meter check light turns on
    if speed remain below 30KM no check light turns on
    can someone help?
    and please suggest me a good engine oil as well thanks
    siliconbwp's Avatar
    Feb 2015
    Bahawalpur
    28
    9
    problem was fixed, there was speedometer grip under the battery which was loose. fixed it and problem is gone now
    redsony's Avatar
    Apr 2005
    Gujranwala
    41
    1,037
    Nice to know the fault, the diagnosis and then the remedy from OP even without any response from the forum. Good Job @siliconbwp
    Could you please elaborate a little more about the grip that was loose. Was it a speed sensor affixed over the transmission or something else.
    "BEHIND EVERY GREAT FORTUNE, THERE IS A CRIME"
    siliconbwp's Avatar
    Feb 2015
    Bahawalpur
    28
    9
    Code was for faulty speedometer sensor, sensor can be checked with multimeter, as i explored on internet they say if its open or short, its faulty, but sensor was neither short nor open. So next step was its solenoid. It was also washed then there were a main grip under the battery which was loose. It was creating problem
    tintin1's Avatar
    Jan 2014
    1,842
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    good to know your problem solved.
    The best engine oil for Vitz is ZIC A+ 5w-20 and it gives the best fuel economy.
    You can keep the change interval as 4K
    Be Addicted To Help Others.
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Quote Originally Posted by tintin1 View Post
    Nt 5w-40 ? As recommended in another thread for 1kr ?
    tintin1's Avatar
    Jan 2014
    1,842
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by salmanrasheedpsh View Post
    5W-20 (ZIC A+) & 5W-40 (ZIC XQ) both are fully synthetic oils and meets/exceeds all the latest oil standards.
    5w-40 is usually for longer change intervals.
    And 5w-20 is for best fuel economy.
    Both of these are superb oils.
