Results 1 to 6 of 6
Thread: Vitz turns off after AC gas refil
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    Default Vitz turns off after AC gas refil
    AoA, i have 2006 1300 cc vitz, yesterday i got refrigent filled up as AC gas was low. AFter that, my car frequently turns of while driving, i have to restart again.
    What could be the issue and solution.
    thanks,
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Over charged ac setup or low quality ac gas putt extra load on engine
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    but the car shuts down even when the ac is off, do i need to get computerized scanning and tuning
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Quote Originally Posted by saboor73 View Post
    agreed and probably it is causing the car to heat up and as a result automatic cut off is initiated to save the car from damage.
    get your car AC checked again, by a trust worthy shop or preferably toyota. they might re fill the gas or oil for the compressor too will cost you something however might fix the issue.
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    ok, i will visit abu bakar in g 8 isb. i talked to him, he said the gas might be overcharged, and in case if this is not the issue, then i would need to visit electrician.
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    i visited abu bakar he checked ac, everything was fine, he referred me to asif efi electrician in g 8 markaz, he did computer scan, there were some error codes with regards to throttle, pedal etc. he cleared and now everything fine.
    Thank you all.
