Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Like Tree2Likes
Thread: Vitz RPM drop at D, R gear
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    274
    4 Post(s)
    Default Vitz RPM drop at D, R gear
    AoA
    have 2006 1.3 vitz, at D, rpm drops, i have checked with couple of computerized EFI electricians, they used carbo cleaner spray, for 2 days it ran fine, and now again started drop rpm, what could be the problem and fix.
    thanks,
    hash4u's Avatar
    May 2005
    38
    24,367
    18
    404 Post(s)
    13 Thread(s)
    13
    Complete service of throttle body including iddle control valve
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    274
    4 Post(s)
    I had done complete service of throttle body from G 8 markaz, Asif EFI electrician, i dont know if he did any thing with the iddle control valvle, he just cleaned throttle body, plugs etc. Can you give me more details into valve kind of stuff.
    thank you again for quick info...
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,708
    22 Post(s)
    Also clean ur fuel filter or replace it
    hash4u's Avatar
    May 2005
    38
    24,367
    18
    404 Post(s)
    13 Thread(s)
    13
    If the throttle body was taken out n serviced.he should hv take out the iac valve n serviced it as well.i think he skipped that part
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    274
    4 Post(s)
    i think so....i will chekc with another guy...
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    274
    4 Post(s)
    i was coming from lahore last week, abs sensor ws not working , my mech told me that i was runing car above 120 in 4th gear, coz if abs sensores are not working, 5th gear wont shift....
    can this be a reason of problem in d mode...
    hash4u's Avatar
    May 2005
    38
    24,367
    18
    404 Post(s)
    13 Thread(s)
    13
    Ur car is cvt
    It has no gear changes like conventional auto gear
    Kindly switch ur mechanics
    Abs sensor issue has nothing to do with iddling
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    274
    4 Post(s)
    i will visit mech tomorrow, currently my gas again leaked, when i turn on ac, it puts too much load on enginee, ride gets hard even when i switch off ac, i have to swithc off car then turn ok, which makes it ok. the problem is when i turn on ac, my rpm drops in d mode....
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    274
    4 Post(s)
    can u also suggest mechanic...
    hash4u's Avatar
    May 2005
    38
    24,367
    18
    404 Post(s)
    13 Thread(s)
    13
    For AC visit abu bakar in isb.....just search his name on pw's his address n number would come up
    For mechanical issue see zahid in enercon aabpara pso pump
  12. #12
    shadab_lodhi's Avatar
    Feb 2012
    Rawalpindi
    82
    If you have got the throttle body serviced and all that, make sure that the recommended spark plugs gap is 1.00 mm to 1.1 mm.
    In addition ask your mechanic to perform the following calibrations with a diagnostic computer:
    - Zero point calibration.
    - CVT oil pressure calibration ( If it is CVT equipped car).
    - Sensor G and Yaw rate sensor calibration.
    Hope that works.
  13. #13
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    274
    4 Post(s)
    here is the issue that was diagnosed after visiting abu bakar, and lots of efi electricians.
    My AC compressor is jam which when turned on causes load on engine due to which it vibrates and shakes. When AC Is off, there is not vibration. Abu baker told me that i would need to change compressor, condensor if needed and vales etc. expecting 20K.
  14. #14
    hash4u's Avatar
    May 2005
    38
    24,367
    18
    404 Post(s)
    13 Thread(s)
    13
    He told u max amount....worst case scenario
    Sad part is ....alot of summers is still left :/
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by shadab_lodhi View Post
    Hope that works.
    the most important bit.
    the throttle body relearn....
    @sohelahmed
    what engine and trans does your car have? - does it have the 1.3 corolla engine
  16. #16
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    274
    4 Post(s)
    yes sir, it has cvt and 1.3 xli/gli engine...
  17. #17
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    what is the idling rpm when in gear?
  18. #18
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    274
    4 Post(s)
    i dont know actually, i am checking with samandar khan efi electrician in sddar, he checks on computer, so far its diagnosed that its not rpm issue, it only occurs when i turn on ac which is faulty, my compressor is faulty, its jammed, i need to replace it. otherwise car runs ok
  19. #19
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    connect any scan tool and see the rpm at idle when in gear.
  20. #20
    nawaza's Avatar
    Mar 2015
    44
    Visit Enercon in G-10 those guys are the best with vitz get your car checked from them and your problems will be solved.
