Results 1 to 6 of 6
Thread: Vitz Maintenance
    ias
    ias is offline
    ias's Avatar
    Sep 2006
    36
    25
    Default Vitz Maintenance
    Hi ALL
    I have purchased vitz 1999 2 weeks ago. Before that i was using mehran (huge difference) .. I wanna know what should be the maintenance schedule for vitz. Please help with the brand names.. Also what should be the tire air pressure in 4 wheels??
    Thanks
    szuberi's Avatar
    Mar 2005
    Toronto
    41
    3,576
    check the white sticker on the inside of the driver side door for correct tire pressure on all four sides.
    for maintenance....did u check with toyota if they have anythng available.
    since these auction vehicles dont usually come complete with service history...it is a good idea to all the basic work done at the same time.
    oil change, all fluid change, brake maintenance, basic tuning including plugs, wires, dcap, rotor, pcv etc.
    check with storm/sameer..he got a vitz recently and he can give u more info on how to get started.
    I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it..and so restriction of free thought and free speech is the most dangerous of all subversions.
    UsmanAnsari's Avatar
    Jan 2006
    38
    7,686
    4 Post(s)
    man u must be feeling like in heaven to have a vitz after mehran!
    i think zuberi said the right things... do what he said
    don't love the car you own.., own the car you love!
    my blog: CarSpiritPK.com
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    490 Post(s)
    19 Thread(s)
    hello!
    1st comparing mehran with VITZ...................!
    not a good idea.....better compare with some MARCH or CUltus or SANTRO...
    anywayz......its mentioned on Driving Side Door mostly...so get the proper reading from there and plz buy your own Guage not worth than 250/- tyre shops guages are simply suckers...so get you own.....!
    maintain weekend oil checkup of
    Brake Oil
    Power Steering Fluid
    Radiator Water(Daily)
    Engine Oil
    Tranny Oil(for Auto)
    Prefer Caltex Oil on all.........if u need better...ZIC is the one stage ahead....!
    change engine oil after 4500km max.....!
    never ever get water inside engine room while servicing car or you end up damaging some sensors or electricals inside.......!
    Thanxxx
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    ias
    ias is offline
    ias's Avatar
    Sep 2006
    36
    25
    Thanks to all for the replies... I will contact storm for his personal experiences..
    @SER_GTR
    i dont see anything on doors, though there is one sticker on drivers door but nothing written about tire pressures except japense...
    can i add distilled water in coolant reservior or i need to add only coolant? if yes then which brand coolant is best.
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    490 Post(s)
    19 Thread(s)
    Hello!
    as far as tyre pressure was concerned so...for 13" in my car
    i prefer
    in Summers....
    30 front
    30 rear
    in winters...
    28 front
    30 rear.....
    so maintaining that with weekend check with your own guage let you fell a smooth drive( if some rock won't stuck in tyres grips....:@ i am tired of them and it did specially in new tyres...)
    anywayz...use Orange color Collant by CALTEX....it was good....1/2 litre tin of japanese collant also works fine..it was of i think 50rs...in green colored tin can.....it was also good........
    i prefer to use collant alwayz bcz it keep engine internals corrosion proff and clean and helps also in winters as it was anti-freeze...
    Thanxxx
