Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 48
Like Tree7Likes
Thread: Vitz 2003 - Strange Overheat Scenario - Need Advice/Help
    venomdesire's Avatar
    Mar 2008
    28
    572
    5 Post(s)
    Default Vitz 2003 - Strange Overheat Scenario - Need Advice/Help
    Dear All, Need your help.
    I have a Vitz 2003. There is a strange overheating scenario.
    1. During Normal Driving (With or Without AC - Single / Two persons on board) : Car Behaves Normal
    2. During Fast Driving (High RPMs) and more than 2 people on board : Car starts to overheat. The Red Overheat light starts flashing. If i quickly get to Low rpms and start driving slow, it goes away, otherwise it eventually causes heatup and the water in radiator/reservior boils and evaporate.
    On highway this phenomenon even observed on 60km/h speed.
    Quite an annoying issue, need a fix.
    Already got the Radiator checked, its rust free.
    Car is Vitz 2003
    Milage : 100k KM
    Driven on : CNG+Petrol
    "Good Judgement Comes from Experience,
    And alot of Good Experience Comes from Bad Judgement"
  2. #21
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by venomdesire View Post
    I know its not the best solution out there, but thats the better choice compared to getting the original-look-alike pumps from the spare parts market.
    as most JDM importers on PW say - its easy as chips to import anything from outside Pakistan, why not import an original toyota water pump and radiator for your car.
  3. #22
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    Yes i have same scenario, the radiator is clean and clear. No corrosion anywhere in the radiator (although when i had opened the thermostat valve it was chocked to death with rust).
    Secondly, is it necessary to get it shaped again from Leith machine??? I frankly am not too comfortable with the leith guys and kharadias (never rebuilt confidence in them after some ugly incidents)..... cant i just change the gasket only??
    Thirdly what belts and seals did you change? Estimated cost and time ???
    flat planing the block deck and head is only done if they are actually warped out of shape - Use an engineers straight edge to verify, dont machine if not needed.
    if machining is needed then please remember that this is a full aluminium engine and uses a steel headgasket, the finish required on both head and block is very very smooth 50Ra or better, this finish gives off a rainbow shine when seen with naked eye. If the finish is rough the gasket wont seal up.
  4. #23
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    Any coolant with anti-cavitation and good head-conducting properties that you can recommend ?? Which is available in the market ?
    caltex coolant, toyota red, fuchs premix, Mercedes Benz coolant, Honda blue etc.
  5. #24
    just_a_legend's Avatar
    Jun 2015
    60
    35
    General causes of overheating.
    Most common issue's.
    Radiator fan is not functioning
    radiator cap is faulty
    Brakes are jammed
    Head leaks
    Bad Engine oil/ very thin may be 5W20 or over usage of oil millage
    1.Coolant related issues
    a. start the car when not hot may be in the morning.
    b. open the hood.
    c.remove the lid of coolant radiator or resorvior.
    d fill it up to the top
    Observe
    Are there air bubbles appearing in the water?
    If yes
    are the bubbles tiny and constant
    or Are the water bubbles big and constant
    Or
    a bubble appears every few second.
    If there is no bubble Your head gasket is fine
    If the bubbles are constant and tiny there is a leak in the head
    If the bubbles are Big then there is substantially leaking head gasket
    If the above is not an issue then.
    Check the lid of the radiator It has two functions , on running it lets the water go to reservoir On cool down it lets the removed water sucked into the radiator , any of the two functions can cause reduction of water eventually heating up.
    Does the fan work and cick in at temp above Normal operating temp Observe the fan.
    Radiators need to be opened and cleaned up , there are a few pipes blocked if you are using tap water. When was the radiator cleaned from inside This could be the cause.
    Jammed breakes cause stress to the drive train check the 4 wheels for any of the two jammed , or after driving 3 km touch the lug nuts and see how hot are they
    Your grade of oil might be 5 W 20 which is meant for 0 meter cars only you need grade 20W50 and change it every 2500 km without fail.
    I would suggest that you get your radiator Cleaned up from the interior and enjoy the luxury of this car.
    Do take the temperature issues serious . Why don't you get in cabin temperature gauge installed Some place that it does not gives a bad look. it will give you exact status of the engine temperature.
  6. #25
    ahsanonline's Avatar
    Jan 2007
    Rawalpindi
    86
    2,295
    19 Post(s)
    3 Thread(s)
    1. What sort of 'stuff' are you using as coolant? Tap water? Pure osaka? Diluted osaka? Anything else?
    2. Before you let anyone get all Tazmania with your engine head, you'd want to get a 15-minute compression test done; compare readings of all cylinders.
    When you say radiator is rust-free, how did you arrive at such a conclusion? What kind of tests/inspection?
    If your vehicle engine has had severe overheating episodes, you may very well need a new gasket+head job done by someone who knows what they're doing & why. And even then there is no guaranteeing that it won't overheat again unless you diagnose & fix the problem that caused the damage in the first place.
    Ofcourse I've seen a govt vehicle's engine being torn down 5-mins after it was driven into a roadside garage - no testing no diagnosis, just plain old "vaal khatam hogae nay"...
    Selling Vitz+local cars - compatible bluetooth Ecu Scantool, High-amp car chargers, Apple-certified Lightning Cables, etc. Click on my name and see my started threads for details.
  7. #26
    molvi82's Avatar
    Jul 2007
    18
    About the gasket change only, once u open the top and see the condition, then only a decision can be made.
    The seals were for engine and so were some vacuum pipes that were cracked. Can't exactly pinpoint.
    The work costed me Rs 6000/- in total including the Lethe guy labor and gasket from Toyota.
    But it definitely has removed the problem, especially after the 1100km test at 40 degrees I did this past weekend.
    Allah Allah Allah Allah Allah
  8. #27
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by just_a_legend View Post
    Brakes are jammed
    Head leaks
    b. open the hood.
    Observe
    If yes
    Or
    so - lets get something straight
    use 20W50 oil and change it every 2500 kms? - oil free aaraha hai aajkal?
  9. #28
    margallar's Avatar
    Oct 2009
    9,958
    6
    283 Post(s)
    4 Thread(s)
    will glysantin g40 work, i bought it mistaking my radiator for an aluminium one, in reality it was brass. so i have a bottle of coolant lying useless
    haters gonna hate, potatoes gonna potate
  10. #29
    Mar 2008
    28
    572
    5 Post(s)
    Hi Ahsan,
    I am currently using a almost 50:50 mixture of Tap-Water and Diluted Osaka (It took 1.5 liters of coolant and some water for the whole system). Nothing else that i know of.
    As for the compression test, i'll try to locate a workshop that can do it for me in this week.
    Thirdly, i concluded about the radiator being rust free for 2 reasons:
    a. replaced it last year with a radiator from a half-cut , it was sparkling rust-free at that time.
    b. Currently drained the radiator, no sign of rust in the drainage water.
    Secondly it did have one overheat episode in which it automatically turned off, and refused to start (didnt take self) until it cooled down.
    Thats the point i want to stay away from Tazmanian Devil type mechanics.
    Well,
    Quote Originally Posted by ahsanonline View Post
  11. #30
    Mar 2008
    28
    572
    5 Post(s)
    Mujhe dedo !
    Quote Originally Posted by margallar View Post
  12. #31
    Mar 2008
    28
    572
    5 Post(s)
    And there it went again last night -___- !
    Started blinking with AC on after half an hour of driving. When i turned AC off and lay my foot off the gas pedal, it stopped blinking. And this kept on going till Clifton ! i kept on turning AC on and Off. When i got home though i saw that water is still in radiator/bottle and it has not evaporated.
    Vitz 2003  Strange Overheat Scenario  Need AdviceHelp -1588133
  13. #32
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    PULLEY is creating havoc the harmonic balancer is having cracks
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  14. #33
    umar47's Avatar
    Jan 2014
    Rawalpindi
    153
    6 Post(s)
    Ahsan brother can u please suggest some shop in rwp for compression test of cultus
  15. #34
    Jan 2007
    Rawalpindi
    86
    2,295
    19 Post(s)
    3 Thread(s)
    Quote Originally Posted by umar47 View Post
    3S dealerships usually do those. Other than that I don't know of any place in rwp (there would be places, but I don't know about them). I also want to get a compression test done, so when you find out where in pindi/isb...let me know!
    Hi Ahsan,
    Well,
    Consider that 'coolant' mixture - poison. A proper flush with mild acid, then a neutraliser, then proper coolant (Toyota's LLC 3.7 Litre tin).
    With that earlier overheat episode, the engine might've lost its 'leaktighness' - the compression test should tell something. What Xulfiqar bro said above about head planning, you would have to do that if and when you find out that you have head-gasket troubles and have to take the head off the engine block.
    For now, first compression test. If you would rather just go with other stuff, drain all from radiator and block, and refill with something proper like zic premixed coolant (order online for home delivery) or use toyota's premixed. Also, a thermostat valve is a must. Its relatively cheap so replace that too.
  16. #35
    umar47's Avatar
    Jan 2014
    Rawalpindi
    153
    6 Post(s)
    Do you have any idea of costs
  17. #36
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    Compression test member @rozzzzz wld do it 4 u in his workshop
    U may also go to pso aabpara enercon to get it done
  18. #37
    umar47's Avatar
    Jan 2014
    Rawalpindi
    153
    6 Post(s)
    I have qouted roz but he has not replied also no Pm allowed on his profile in abpara there is a shell pump a pso pump is in melody I guess
  19. #38
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    Eeks....i meant melody....next to old isb hotel
  20. #39
    umar47's Avatar
    Jan 2014
    Rawalpindi
    153
    6 Post(s)
    Ok got it so is there a mechanic on this pump or pso has this facility
  21. #40
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    Next to tuck shop of pump is enercon shed. talented mechanic.
Tags for this Thread
