Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Like Tree5Likes
Thread: Vitz - 2013 - Advice regarding newly purchased car
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Default Vitz - 2013 - Advice regarding newly purchased car
    Dears AOA... I recently bought a 2013 Vitz, 50k driven. Imported in Mar 15. Need advice on whether to change the Engine, CVT oils or not. If Yes, which brand is recommended for both oils. Secondly, it has a Pioneer Carrozeria DVD but won't play Video. Audio working good. Thirdly, advice on seat covers. I also like to install a rear view cam. Which one no where from.. I'll be grateful if the expenses r also mentioned by respected members alongside their advice.. thank you
    No other man-made device since the shields and lances of the ancient knights fulfils a man's ego like an automobile
    Akhan12's Avatar
    Mar 2012
    Peshawar
    94
    How much it costs you?
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    14,00,000
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Liqui moly fully synth 5W-40 for the engine oil along with 1ceratec can and 1motor peotect can. But be sure to flush up the old engine oil with same LM engine flush. And then change it with above mentioned oil and treatments you will love your ride when you drive it.
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    Quote Originally Posted by rajaatta View Post
    It's 2013 model with 50,000 KM on the odometer. Why not 5W30.
    5W40 shall be too thick at this stage. He may start using 5W40 once 100,000 KM are done.
    Don't leave a highway for a byway....
    nawan885's Avatar
    Jan 2008
    36
    604
    8 Post(s)
    you should not change cvt fluid as it should be changed after 100000 miles. and for engine oil 5 or 10w30 is good as I am using that
    COOLTAHIR's Avatar
    Feb 2011
    Select City
    19
    4,702
    9
    132 Post(s)
    3 Thread(s)
    sorry for offtopic :
    does vitz comes with cvt transmission ?
    FeeL YoUng DriVE YoUnG......
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    Quote Originally Posted by nawan885 View Post
    Please re-check. CVT transmission oil change is recommended to be replaced at 40,000 KM here at PW forums.
    talha.b.khalid's Avatar
    Aug 2014
    26
    11
    Congrats on purchase
    Aug 2014
    26
    11
    owner manual can help you regarding oils
    mention the DVD model number so it can be sorted out
    Net material seat covers are usually heat friendly but they catch dust the most will cost you around PKR 3500
    Leatherite material are easy to clean costs almost same
    Rear camera is easily available on car entertainment shops ranging from PKR 1500 - PKR 7000 depending upon quality
    Cr33D's Avatar
    Nov 2012
    Rawalpindi
    21
    585
    15 Post(s)
    Change your CVT oil(use Toyota one), get your spark plugs cleaned, change Oil/Air filter, Break oil should be checked, if it's too dark in color then it should be changed as well, I recently used Zic A+ 5w-20, you can use 5w-30 as well.
    Keep good care of CVT if you want it to last long. As far your last part, i got back view camera installed for 3500rs, go to any car electronic/audio shop and they can install it for you.
    When I looked up "Ninjas" in Thesaurus.com, it said "Ninja's can't be found" Well played Ninjas, well played.
  12. #12
    Cr33D's Avatar
    Nov 2012
    Rawalpindi
    21
    585
    15 Post(s)
    Quote Originally Posted by COOLTAHIR View Post
    Yes it comes with CVT.
  13. #13
    nawan885's Avatar
    Jan 2008
    36
    604
    8 Post(s)
    Quote Originally Posted by imrananr View Post
    I have checked cvtF change time in manual but not mentioned. in uk and Europe for yaris/vitz company recommend 100000 miles. but here in pk if you visit authorised 3S shop there company recommend to change it after 40k. when I ask why it should be changed as there is no problem I am facing with transmission. . His only answer was... janab ham to altis auto ka 40k per change kerty hain...this appears non sense to me.
  14. #14
    Cr33D's Avatar
    Nov 2012
    Rawalpindi
    21
    585
    15 Post(s)
    According to Manufactures(Toyota) Maintenance Schedule, for CVT
    Normal Condition - 60,000km/48 months - Inspection.
    Severe Condition - 45,000km/36 months - Inspection, 90,000km/72 months - Replace
  15. #15
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
  16. #16
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    I had maintained so many of these new version vitz few out of 50 vehicles had original mileage on them if the vehicle is driven 50000km on odo it must have been driven more and in result the meter is reversed back for getting good resale price. It can easily be checked through techstream. 2nd here in pakistan. The 5W40 is a good go for these engines. Many of my clients had used low viscosity engine oil like 5W-20 5-30. In their new vehicles and after driving 5 to 10 k their engines were more noisy than of normal vehicle. So 5W-40 is best for all jdm engine brands except for some diahatsu,nissan & suzuki 660cc varient engines which are designed for low visc oil. If not followed properly they suffer from fuel eco low problem.
  17. #17
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Dont forget to flush the old oil with engine flush as it will clear the oil galleries from sludge and also clears the vvti cam gear oil galleries for better flow. And also use some oil additives to keep these jdm engines run smoothly and can handle the abusive driving of our daily routine drive.
  18. #18
    nawan885's Avatar
    Jan 2008
    36
    604
    8 Post(s)
    great. what kind of oil flush should be used. and what kind of oil additive is recommended
  19. #19
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Many thanks for your worthy comments.. engine oil changed after flushing ... mechanic recommended CVT oil change after 80k kms..
  20. #20
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Can u recommend any oil additive?? Brand name, I mean.. along with specs
