Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Like Tree5Likes
Thread: Vitz - 2013 - Advice regarding newly purchased car
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Default Vitz - 2013 - Advice regarding newly purchased car
    Dears AOA... I recently bought a 2013 Vitz, 50k driven. Imported in Mar 15. Need advice on whether to change the Engine, CVT oils or not. If Yes, which brand is recommended for both oils. Secondly, it has a Pioneer Carrozeria DVD but won't play Video. Audio working good. Thirdly, advice on seat covers. I also like to install a rear view cam. Which one no where from.. I'll be grateful if the expenses r also mentioned by respected members alongside their advice.. thank you
    No other man-made device since the shields and lances of the ancient knights fulfils a man's ego like an automobile
  2. #21
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Quote Originally Posted by talha.b.khalid View Post
    Congrats on purchase
    Thanx Talha...
  3. #22
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    owner manual can help you regarding oils
    mention the DVD model number so it can be sorted out
    Net material seat covers are usually heat friendly but they catch dust the most will cost you around PKR 3500
    Leatherite material are easy to clean costs almost same
    Rear camera is easily available on car entertainment shops ranging from PKR 1500 - PKR 7000 depending upon quality
    It's Pioneer Carrozzeria AVIC-MRZ 05... does it include the Nav System as well? I have no idea.. As of now, it plays the Audio media, but not the Video
  4. #23
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Quote Originally Posted by rajaatta View Post
    Liqui moly fully synth 5W-40 for the engine oil along with 1ceratec can and 1motor peotect can. But be sure to flush up the old engine oil with same LM engine flush. And then change it with above mentioned oil and treatments you will love your ride when you drive it.
    Dont forget to flush the old oil with engine flush as it will clear the oil galleries from sludge and also clears the vvti cam gear oil galleries for better flow. And also use some oil additives to keep these jdm engines run smoothly and can handle the abusive driving of our daily routine
    Sir, I don't mean to challenge your experience and since I'm new to Vitz so I'll just seek further clarification. Do u think that an engine as new as Vitz 2013 ( even if it's 50-100k driven) will have oil residue clogged around VVTI cam n oil galleries? Secondly, when we decide to use the best available engine oils available in market, Why do we still need additives? Is a good oil not optimally formulated to take care of the engine, especially when one of it's main functions is engine cleaning? Thank you
  5. #24
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Engine cleansing through oil is good enough but keep in mind that why the old version vitz is suffering from excessive knocking issue because we had previously experienced by putting all of the duties on regular engine oil. Like. Engine lubrication., thermal absorption, and cleansing on oil which in end result's in knock issue which cant be resolved later due to the damage already done. So by the experience of those faults which we had suffered in past directs us toward the fix viscosity synthetic engine liquids along with oil additives to suppress those symptoms and protecting engine from any sort of harm like low lubrication problem at peak performance. Increased thermal efficiency to keep the internals temperature low, and super cleansing and cleaning properties to keep the engine oil. Galleries tidy and shiny to perform better than stock vehicle. Is the concept is clear or should I had to describe it more briefly / in detail.
  6. #25
    talha.b.khalid's Avatar
    Aug 2014
    26
    11
    Quote Originally Posted by adil39 View Post
    This model is capable of playing audio formats only it has cd player so it cannot read dvd, and i think it is also not capable of reverse camera too, yes navi is there but as its a typically japanese player so it will have maps of japan only, any car entertainment shop wala will guide if maps of pakistan can be added or not?
  7. #26
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Well explained bro... so now the second issue is the quantity. Vitz needs 3.5 lits of engine oil. To be precisely accurate about the requirement of oil in the engine, we need to precisely work out the amount of engine oil + additives (ceratec can & motor protect can). Can u please tell me the exact amounts ? Do these cans come in one quantity or differ? R these all LM products? I just want to be sure that engine doesn't get over filled. This time my bro took the car for oil change and he put Total Quartz fully synthetic 5W-20 in Vitz. Next time I'll put in 5W-40 as recommended by you. Thanx.
  8. #27
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    This seems to be a sorry state bro.. what to do now? I'm not much interested in Nav but I'm very much interested in DVD Video and support for rear view cam... What Options do i have ????
  9. #28
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    I'm also interested in leatherite material seat covers. Can u recommend any Vitz specialist with regards to seat covers? Pindi / Islamabad. Though I love it's original seat fabric but it's because of the colour that I want to cover them.. thanx
  10. #29
    bilalalam's Avatar
    Nov 2008
    40
    449
    8 Post(s)
    My thoughts exactly - most German and American engine oils already come with detergents to clean the engine along the way- i always wondered if flushing the engine was such a good idea why would the maintenance schedule of all cars include it?
    here are the 3 main reasons for engine knocking
    Engine Knock Causes - What is engine knock?
    Drive carefully! Remember, it's not only a car that can be recalled by it's maker.
  11. #30
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Quote Originally Posted by bilalalam View Post
    a good read to know the main causes of engine knocking.. thank for sharing
  12. #31
    fouadbakht's Avatar
    May 2006
    3,620
    20
    140 Post(s)
    Adil, first off congrats. I bought a 2013 Vitz in white colour with 1.0L. If possible do check out my thread for helpful tips. Also share your knowledge so that noobs like me and respected members may benefit
    Sent from my iPhone 6 Plus using PW Forums
    https://www.facebook.com/hidefcars
  13. #32
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Quote Originally Posted by fouadbakht View Post
    Fouad Bhai... Thanx a bundle. I'm already there... actually to be very frank, it's your thread where I'm following your Dart and getting benefitted.. I'll express whatever little knowledge I have about autos in general.. thanx
  14. #33
    bailcha's Avatar
    Sep 2015
    Select City
    31
    Can you recommend any shops in Karachi if possible. Thank you
    Sent from my Nexus 4 using Tapatalk
  15. #34
    zulayed's Avatar
    Sep 2013
    181
    please refer to the manual for engine oil. 5w40 is thick for vitz and will not give optimal fuel economy. do not use a thicker oil than a 30 grade oil. i suggest to use 0w30 or 5w30 all year round. car manufacturers know whats best for their engines. the engine runs at the same operating temp during both winters and summers. unless u take the car for continuous high speed racing do not use oil thicker than a 30 grade.
