Results 1 to 3 of 3
Thread: vitz 2000 problem with manual gear
    tahir_gpk's Avatar
    Apr 2012
    Gujranwala
    Default vitz 2000 problem with manual gear
    aoa. iam facing missing problem in vitz 1999 model with manual gear . car is missing between 1100 rmp to 1400 rmp with and withour gearing mode both. i already change spark plugs and injector and quails. and also change airfilter sensor but no rsult. plzz help.......
    tintin1's Avatar
    Jan 2014
    1,842
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by tahir_gpk View Post
    Reasons can be many. you need to see good mechanic or take your car to 3S for inspection.
    They will charge 200~300 to inspect your car.
    which engine oil & gear oil you are feeding?
    Be Addicted To Help Others.
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    Cng installed? Disconnect emulator wiring.
    Another Possibility of bad valves
