Results 1 to 5 of 5
Thread: Fog Lights Installation - Vitz 2013
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Default Fog Lights Installation - Vitz 2013
    Dears, can anyone suggest any good electrician in Pindi/Islamabad who can install decent foglights in my Vitz without screwing the wiring. I read in some posts on Pakwheels where guys went to some Ustazzz Jeee for fog lights installation and ended up playing with the fuse box n engine check lights blinking. I would rather not get the lights installed than doing experiments, since these sensor based engines r quite sensitive to voltage fluctuations.. thanx
    No other man-made device since the shields and lances of the ancient knights fulfils a man's ego like an automobile
    KhurrumIftikhar1's Avatar
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    Quote Originally Posted by adil39 View Post
    Install fog lights and give them the connection directly from head lights.
    or
    Install wiring that comes with fog lights.
    but some times there will be pre installed wiring of fog lights in vitz like in mine but no fog lights.
    never ever try to connect your fog lights with that wiring.
    because i tried it and after installing fog lights with that wiring in my 2014 modle vitz bought in 2015 march .
    I end up with ABS and CEL .and problem turn out to be damaged ABS unit .Then Definately replaced the ABS unit.
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Quote Originally Posted by KhurrumIftikhar1 View Post
    or
    Oh man... that's another sad story.. I think I better not install fog lights.. I mean sacrificing ABS for fog lights is too much. Even as u mentioned connecting directly from headlights, isn't advisable. U r actually taking the voltage share of headlights and giving half to fogs. In my humble understanding, either there should be a separate wiring already designed for fog lights or there has to be a direct connection from the battery bypassing all other connections but in no case, sharing of voltage with other electrical components. Thanks
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    Yes the electric connection will be directly from battery. The wire connected with headlights determine either head light is on or off so as soon as you turn headlight on fog light will turn on.
    I am using this setup in my corolla gli 1.6 since 2012
    Its the best method.
    Uptil now no problem with headlights and fog lights.
    Also using this method in my vitz for 3 months no problem.
    Because fog lights get power from -ve and+ve terminal of battery. Only a single wire is attached with headlights wiring.
    Do install fog lights in your vitz the look good as well as beneficial
    adil39's Avatar
    Nov 2006
    Wah cantt
    200
    8 Post(s)
    Thanx bro.. but why to keep the fog lights dependant upon headlights? I mean can't we have a separate button installed for foglights? I want the fog lights to work independent of headlights.
