Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Like Tree8Likes
Thread: Best Vitz Mechanic in Rawalpindi / Islamabad
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    Question Best Vitz Mechanic in Rawalpindi / Islamabad
    Who is the best person to have my Vitz (1.0) 2005 checked in Rwp/Isd. The ABS light is not going off. Engine knocking on certain rpm, mileage dropped and loss of power. When accelerating at first the car pick is fine, leaving other cars on traffic lights, but after that around 40-50 it feels as if the car is dragging something (becomes heavy) and engine knock is felt, once momentum takes over and higher rpm, the drive becomes smooth.
    I am using
    Liqui Molly 5W-30 engine oil.
    Original oil filter
    Original Air filter
    Original Drum brakes replaced with another pair of genuine pads but they squeal when slowing down for speed bumps etc.
    Replaced spark plugs with Toyota iridium about 6 months ago.
    Never had exhaust system checked though. People suggest removing CAT converter but I am not convinced as it's just word of mouth but no information on how it affects the engine in long run.
    Never had engine tuned up or ratios reset. Which I think is the case here but I am unable to find a qualified person in Rwp. My regular mechanic, though expert with automatic imported cars, still haven't been able to restore power and mileage. All he suggests is to change CVT fluid but I had it replaced about 40K km earlier.
    Any my more suggestions ?
    Sent from my iPad using PW Forums
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Get It OBD Scanned And Diagnose The Error Codes..!
    2ndly Check If There's Any Smoke Or Any Sign Of Oil Burning Or Reduction Of Oil LEVEL....!
    For Knocking Try A Ratio Of 60/40 For Super To HOBC And See If It Helps....All High CR Engines KNOCK.....
    CVT Oil Need To Be Changed Every 50k Km....!
    @hash4u @spectra Can Guide You Abt Best Place To Get It Diagnosed With proper OBD-Scanner ...!
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    Quote Originally Posted by SER_GTR View Post
    No reduction in oil. No smoke through exhaust normally but sometimes low grade fuel makes smoke but disappears after revving the engine.
    Yes. The knocking reduces when high octane is mixed in. But I haven't tried 60/40 ratio. I use injector cleaner regularly which also helps reduce knocking but it doesn't disappear.
    I changed CVT fluid at 35K ODO. Now it's at 79K on ODO.
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Quote Originally Posted by AlienX View Post
    CVT Oil Change Due After 6k kms.....For Knocking You Need To Use HOBC Since Our Super Unleaded Is LOW RON..Choose Best PUMP In Town For Fuel Refill And Don't Change It....Get Your HOBC Mixture Adjusted On Regular Basis.......However Get It OBD Scanned For Finding If There's Any Sensor Malfunction Also....!
    Valve Seal Leak Can Be Detected Early 1st Time Start In Morning With Kinda Blue Smoke...! Watch out For Smoke On 1st Morning Start-up To Verify...! if Not..You Are GOOD With Oil Leak....Power Reduction Can Be Due To Many Factors.....Weak IGN Can Also Cause So As Bad FUEL / Sensor Malfunction Or Mixture Adjustment...
    Get OBD Readings And If Possible Check For Live Feed And Inspect How Your O2 Sensor Is Working ...!
    Bad Mileage Can Be A Symptom Of Busted O2 Sensor
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Bro have to test driven same gen 1L vitz other thn urz ?
    May be m wrong but this power loss ur talking abt in 40-50 kmph band is i guess kinda normal for this car and engine as its a bit underpowered
    I also use 2nd gen vitz
    Recommended cvt oil change interval for it is 40k km
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    Thanks for detailed reply.
    Ok. I'll have OBD readings. Talked to a guy Atta-ur-Rehman. He has a workshop near faizabad (Rehman Motors). Another user on this forum had very good experience so I'll go when get some time.
    What does 1 bar on fuel gauge represents? May be I am calculating mileage wrong. As I haven't been on long route for some time.
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    Quote Originally Posted by salmanrasheedpsh View Post
    No I haven't tried another vitz. Just once test drive a 2011 model but the car was almost new so couldn't guess if it had anything off the normal behavior. But this power loss which is kind of heavy feeling has started in last 2000km run but improved by 50-60% after engine oil change.
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    No I haven't tried another vitz. Just once test drived a 2011 model but the car was almost new so couldn't guess if it had anything off the normal behavior. But this power loss which is kind of heavy feeling has started in last 2000km run but improved by 50-60% after engine oil change.
    Hope ur issue is resolved soon
    Better test drive same model vehicle to get an idea
    For abs light get it scanned and ull know the source of problem
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Bars Can't Tell You Anything....! A Full Tank Or Half Talk Refill Or Getting 1000rs Fuel And Driving It For Certain Km And Refilling Again And Checking Drop Level Every time Can Tell You How Much Mileage Its Doing...
    Just BE Careful When Getting It OBD Scanned....Don't Just Believe Everything What They Have To Say....!
    That's Why I Recommend Senior Pw's Members From Twin Cities To Guide You On Right Path
    Get Pictures Of OBD Readings When Done For Record Purpose ..A Live Feed Readings Also Tell You If Your o2 Is Fine or Not
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Allah ap ko mahfooz rakhay .. he is a brother of agha watar of water fuel and rip of ppl nicely
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Bro 1 bar fuel equals 5 liter
    Its my calculations may be its incorrect
    The tank is of 42 liter capacity divide it over 8 bars
    U get 5.25 liters
  12. #12
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Expect 13-15 kmpl in isl urban 16-21 on motorway all depending on ur driving speed , style and weight
  13. #13
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    U get 5.25 liters
    Yes, My own observation is the same. Though it's not linear, when tank is full the top bar runs for 60+ Km, but middle ones run for around 40-50 Km depending on traffic, AC and number of passengers.
  14. #14
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    More like 9-11 for me. I'll have wheel alignments checked though, they often mess up mileage. About driving style, I know CVT engine has linear curve and no matter if you floor it or not, the speed will go up steadily. So light foot on throttle is how I drive.
    What about keeping the car in D when stopping on traffic lights, or do you put it in N ?
    I do have 14" Alloy Rims with larger tires than normal, I guess they are 185. I bought the car with Rims already fitted.
  15. #15
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    @SER_GTR do you think weak fuel pump or old fuel filter might be causing engine to suffocate when RPM increases. My car does take 2x self for cold start but often takes a long self to start.
    When I bought the car, the owner had the faulty fuel pump replaced with a corolla one (Modified by mechanic). Don't ask how I found that out. Just imagine standing in full sunlight in june at 4PM at the middle of traffic stop.
    Anyway I found an original (not sure) fuel pump from market for around 10K and have been using it for last 3 years but it did gave problems about 1.5 years ago and mechanic told me to replace it but I refused as it's costly. Now I think it may be causing problems like loss of power when throttle increases or knocking.
    I think only OBD readings can tell about the real issue.
  16. #16
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Replace Fuel Filter If Its Dirty.....Fuel Pump Pressure Can Only Be Checked Using Fuel Pressure Gauge....!
    Simple OBD Code Reader Can't Tell That Much But Short Term Fuel Trim Long Term Fuel Trim Can Def Tell You The Story.... If Someone Knows How To Read And Chk....
  17. #17
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Well dat mileage is less if driving in isl
    Ive used my vitz in isl local gives a minimum of 13.5 kmpl
    I shift it to N , dun knw if dat beneficial or nt, just a habit
  18. #18
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Dat self thingy ur talkin about , hope ur using the correct viscosity engine oil , too thick engine oil also causes this on a cold start up in vitz
  19. #19
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    In Summers It Wont Hurt Much But In Winters Where Temp Drops Upto Below 10-15 Degrees..Then Yes...It Does Make Your Starter Sound Heavy.....!
  20. #20
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Always Good To Shift To N If You Know Its Gonna Be A Bit Long Stay On Signal....It Will Disengage Any Stress Away From Tranny....!
